Home Theater Systems - Electronics and Forum - HomeTheaterShack - View Single Post - Corner Trap Placement
View Single Post
Old 01-16-07, 09:44 AM   #5 (Link)
Glenn Kuras
GIK Acoustics
Alias: Glenn Kuras
Loc: Atlanta, GA
Glenn Kuras's Avatar
User: #2464
Since: Sep 2006
Glenn Kuras is offline
Re: Corner Trap Placement
basementjack wrote: View Post
I'm going to go out on a limb here and suggest that you might not need bass trapping in that room.
- Jack
Then you are going to be out there all by yourself!!!
Yes it can help (or maybe hurt) to have the openings, but every room needs bass traps.
basementjack:
It looks like we would have to really dig into your room to come up with a good plan for you and IF YOU WIN then we would be more then happy to come up with something for you. Sounds like to me you are going to have to be creative about placement. But even with that said most any corner is going to benefit from bass trapping.. I would think about the one corner you may have open in the front as a start. MAYBE!
Glenn
Glenn Kuras - GIK Acoustics
www.GIKAcoustics.com
