Home Theater Systems - Electronics and Forum - HomeTheaterShack - View Single Post - First graph
Thread: First graph
View Single Post
Old 04-28-07, 11:36 PM   #9 (Link)
Alias: brucek
User: #6
  brucek is online now
Re: First graph
I’d try smoothing your graph to 1/6-octave (or whatever brucek usually recommends
Well, actually we only use smoothing for full range measurements, where reflections can cause comb filtering that makes it difficult to see the underlying trend of the response. It is rarely used for low frequency measurements as it would obscure the true shape of the response and so not allow accurate correction filters to be determined.
is this what I'm looking for??
Yep, I wanted to see if the mains were influencing the sub in that dip area around 30Hz, and they're not.
You've got about four peaks that could be equalized and would result in a much smoother result. I'm sure if you use REW to find peaks and then assign filters and play around a bit, you will reveal what the final response would look like if you used a BFD...
