If you want to do full range measurement you really should get a mic and preamp like the ECM8000 and the
XENYX 802.
The RS meter isn't considered accurate above ~5KHz....
There's little you can do with EQ / Traps / room treatment above that range anyway, so why not give the RS meter a try.
