Home Theater Systems - Electronics and Forum - HomeTheaterShack - View Single Post - speaker testing software.
View Single Post
Old 03-13-08, 06:51 PM   #3 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
Re: speaker testing software.
The recommendation I've seen most often is TrueRTA. It's not best of breed, but it's inexpensive ($100 for level 5 version -- which you want) and easier to use than most. REW is free, but I don't think it does all of the testing stuff you'd want in a testing software. The other thing I'm seriously considering is getting the Woofer Tester from Parts Express. I think between that and TrueRTA, you'd be doing pretty well.
JCD
