Home Theater Systems - Electronics and Forum - HomeTheaterShack - View Single Post - Air tight joints in Birch plywood?
View Single Post
Old 04-06-08, 04:38 PM   #12 (Link)
Owen Bartley
Alias: OJ
Loc: Toronto, Ontario
Owen Bartley's Avatar
User: #3144
Since: Oct 2006
Owen Bartley is offline
Re: Air tight joints in Birch plywood?
Yep, good square cuts, **** joints, glue, and lots of clamps. That should sort you out nicely with either MDF or plywood. And then as has been mentioned, it never hurts to run a bead of caulk or clue around the inside of all your corners, just to make 100% sure you're airtight.
