Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Anamorphic Projection
Anamorphic Projection Theaters
Discuss Anamorphic Projection Theaters in the Home Theater | Audio and Video forum; Anamorphic Projection Theaters This thread is for all members who have Constant Image Height projection, to show off their theatres.. I'm sure there ...
Views: 1721 - Replies: 30
Old 04-29-08, 02:57 AM   #1
Shack Moderator
Alias: Prof.
Prof.'s Avatar
Loc: South of Adelaide
User: #3204
Since: Oct 2006
  Prof. is offline
I'm sure there are few out there, so lets have a look (just out of interest) at what your set up is like..
Information like..
Room size..
Screen size (as in width)
Projector..
Lens..
Seating distance etc..
This information will also help those who are contenplating the move to Anamorphic Projection..
A few shots showing your room and front screen, your projector and lens and just two or three screenies to cap it off would be nice..
Prof..
Home Theatre...the never ending story!
Old 04-29-08, 09:30 AM   #2
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
Re: Anamorphic Projection Theaters
I can't post in this thread
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 04-29-08, 10:38 AM   #3
Alias: Mark Techer
Loc: Brisbane, Australia
User: #15620
Since: Jan 2008
  Mark Techer is offline
I might as well go first
Screen: I have a Curved AT 2.37:1 screen 2250mm x 949mm. The curve is adjustable to optimize for pincushion correction.
The LCR speakers are positioned in the same horizontal plain with their cabnet tops at the centre of the screen line of the screen and where the L and R are just inside the 1.78:1 area. I did this so that the sound to image match would work for all ARs and not just Scope. Also real cinemas and dubbing stages have their L/R speakers there too, so I now hear what they heard.
The screen height si currently 600mm off the floor, but I would like to raise it to at least 800mm, maybe 900mm.
Projector: BenqW5000 with CAVX Aussiemorphic Lens (yes I have prototype MKIII in testing now). The projector is 1920 x 1080 DLP and delivers a spectular image.
Source: HD DVD via a Note Book PC over HDMI.
Seating distance: 2 rows where front row is just 2x the image height. Close but this really works well with a 1080 projector. Back row is just over 3x the image height and is elevated 300mm.
Other Audio: THX 7.1 processed DD and DTS. I use 3 identical LCRs with controlled Vertical directivity and 4 Identical Surrounds (Bipole) and a pair of Subs using Peerless XLS drivers...
Mark
Old 04-29-08, 08:51 PM   #4
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
Thanks Mark..
Mark Techer wrote: View Post
That is quite low..although I bet you get a real sensation of being in the picture, particularly in scenes like SW2..when their flying through the valley, and you're looking through the cockpit window as the landscape is rushing towards you..and when Anakin is flying across the desert on his bike..I find that very real on my screen and mine is 750mm. off the floor!
Mark, I haven't seen your new theatre, so how about some pics?
Also some screenshots please..
Prof..
Old 04-29-08, 09:01 PM   #5
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
blaser wrote: View Post
I think the day is not too far off Ahmed, when you will be able to post here!..
Prof..
Old 04-30-08, 07:05 AM   #6
Alias: Mark Techer
User: #15620
Since: Jan 2008
Prof. wrote: View Post
Hi Prof, whilst I am happy to place a link to screen shots, my cinema is too far from complete to post photos of...
Mark
Old 04-30-08, 07:21 AM   #7
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
Hello, yeah I was just joking. There are some restrictions in my room that make a 2.35:1 setup a bit tricky. At least I will have to use an AT screen + change speaker pacement and subs, not to mention a video processor should be added for Full def material to be able to post here
That's not impossible, but not easy at this stage....espacially when a 16:9 screen is the most versatile screen when you're watching as much 2.35:1 material as 4/3 material on satellite.
Neverheless, I would really like to see people post screenshots of their setups.... Come on guys!!!
Why not start by yourself Prof?
ASME AI
Old 04-30-08, 08:02 PM   #8
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
Yes I will be shortly..I'm just trying to get some new shots of the theatre , to try and show it in it's best light (no pun intended), but my camera won't play ball!
Prof..
Old 05-02-08, 11:17 PM   #9
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
Well I finally managed to get the camera to produce more accurate colours in the theatre pics., so here are my theatre details..
My theatre is fairly small at just 10' 6" x 15', with 7' 6" ceilings, but it performs admirably..
The screen is 8' wide , which doesn't leave much room either side of the screen, so the LCR speakers are mounted above the screen..One of the advantages of CIH with generally lower screen heights..
The bottom of the screen is 750mm. above the floor..
The front row (the only row) seating is at 9' 6" from the screen wall..Although, when I have guests, I can get a couple of dining chairs on the raised platform behind the main seats..
The ceiling mounted projector is a Benq W100 DLP, fitted with an Aussiemorphic lens on a DIY slide..
The next upgrade will be to convert to an HD projector!..
So, this is what my theatre looks like, and a few screen shots to finish off..
Acoustic panels are behind the curtains on both side walls..
And so, on with the show..
Thanks for looking..
Prof..
Old 05-03-08, 03:46 AM   #10
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
IMPRESSIVE PROF
ASME AI
Old 05-03-08, 07:54 PM   #11
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
Thanks Ahmed...
Prof..
Old 05-04-08, 09:49 PM   #12
Alias: Mark Techer
User: #15620
Since: Jan 2008
I like the wall to wall look with that Scope screen Prof - very cool!
Mark
Old 05-04-08, 10:20 PM   #13
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
Thanks Mark...Yes, it was a bit of a bonus having a narrow room, so I could have virtually a wall to wall image..
Prof..
Old 05-22-08, 02:27 AM   #14
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
I can't believe that of all the members here at the Shack, that Mark and I are the only ones who have Anamorphic projection!!..And whe're both Aussies!!
So c'mon you guys from the US and Canada and other Countries...Show us what you've got..
Prof..
Old 05-22-08, 05:12 AM   #15
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
They are afraid they can't compete with your pics
ASME AI
Old 05-22-08, 07:38 PM   #16
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
Yeah right!!
Prof..
Old 08-04-08, 09:32 PM   #17
Alias: tmack
tbase1's Avatar
Loc: medina ohio
User: #3961
Since: Nov 2006
  tbase1 is offline
I've been scope since i completed my new HTR. However, i'm still completing the equipment end (htpc) ,but i will send pic.'s soon. The below is what I have so far by way of equipment.
DIY 8' wide scope
sanyo z4 projector
prismasonic v1000 lens
black plastic hush box
sony bdp-301 blu-ray
toshiba a30 hd-dvd
panamax power conditioner
onkyo sr-605 avr
boston 7.1 speakers system
htpc running visa (party music ,family pictures and video)
two rows for seating with lighted back platform
bistro table and four chairs in the back with over head light
drop down 22" pc wide screen monitor for surfing the net and watching movies
built in microwave ,refrig. ,and candy shelf
door switch controlled lighted theater poster
built in 6' wide saltwater fish tank
light controlled phone and door bell for those people that come late to the showing
Old 08-04-08, 10:29 PM   #18
Alias: Mark Techer
User: #15620
Since: Jan 2008
Cool, looking forward to seeing some picks soon...
Mark
Old 08-05-08, 11:12 PM   #19
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
Good to hear someone else on here has an Anamorphic Theatre..
Looking forward to seeing your pics..
Prof..
Old 08-07-08, 09:31 PM   #20
Alias: tmack
tbase1's Avatar
Loc: medina ohio
User: #3961
Since: Nov 2006
  tbase1 is offline
the one thing i love about this hobby is...it's the gift that keeps on giving.
Old 08-29-08, 07:53 PM   #21
FORK485
Inactive
Alias:
User: #
Posts: n/a
Nice choice of movie poster tbase. Although the first movie was my favourite lol.
Old 09-02-08, 04:47 AM   #22
Alias: Adam
AngelEyes's Avatar
Loc: Cambridgeshire UK
User: #3816
Since: Nov 2006
  AngelEyes is offline
Sorry to hijack this thread but I am quite interested in going the Anamorphic route but don't fully understand how it all works and the logistics of installation. Could someone point me at a decent source of information for the beginer, that explains the basic pros and cons of Anamorphic over 'normal' projection.
Thanks very much
Adam
Old 09-02-08, 09:15 PM   #23
Alias: tmack
tbase1's Avatar
Loc: medina ohio
User: #3961
Since: Nov 2006
  tbase1 is offline
Angeleyes,
This is a subject that is hard to expalin in a post or two, but I'm try to give some high points.
1. allot of movies are starting to come out in scope format...hence no bars on top and buttom with scope screen.
2. more use of pixel structure...hence the anamorphic lens
3. wider angle...hence more panamorphic view
There's more but i think the best place to get a real birds eye review is on panamorphic lens and prismsonic's lens web site. Of which...they are two of the most well known lens companies out there...at least for the guys that don't have allot of jack to spend on a lens.
fork485,
thanks for plugging my HTR.
Old 09-03-08, 03:25 AM   #24
Alias: Adam
AngelEyes's Avatar
User: #3816
Since: Nov 2006
tbase1 wrote: View Post
Angeleyes,
fork485,
Hi,
Thanks for the reply, right after i posted here I found this thread which has helped quite a bit: http://www.hometheatershack.com/foru...ih-screen.html
With reference to point 1 in your post, how can you tell if something is in scope with no black bars on a 16:9 screen (I just have a Plasma at the moment)?
Thanks,
Adam
Old 09-03-08, 03:47 PM   #25
Alias: tmack
tbase1's Avatar
Loc: medina ohio
User: #3961
Since: Nov 2006
  tbase1 is offline
anything 2.33 and up is scope
« Home Theater Shack > Home Theater | Audio and Video > Anamorphic Projection »
