A few Q's - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Anamorphic Projection
A few Q's
Discuss A few Q's in the Home Theater | Audio and Video forum; A few Q's I'm looking to build a 2.35:1 screen and eventually install an anamorphic lens. I am not sure I'm handy enough ...
Old 07-22-08, 01:19 PM   #1 (Link)
Alias: Richard
Loc: Richmond, VA
User: #20916
Since: May 2008
CompguyRG is offline
A few Q's
I'm looking to build a 2.35:1 screen and eventually install an anamorphic lens. I am not sure I'm handy enough to build one on my own, so I was looking at this one http://www.hometheaterbrothers.com/23901.html which I thought was a good deal considering the prices on some of the others out there.
I'd love to hear about any other subsitutes, I just hate to spend that kinda coin. If I had a parts list and some explicit design instructions I might be able to pull it off, but I am a novice carpenter at best.
I'm going to be putting together the screen shortly and I'll be using either a panasonic ax200u or
ae2000u depending on what the price does on the latter over the next few months.
Do you all have any design instructions for the screens? I was going by this http://www.engadget.com/2006/08/29/h...jector-screen/
Are there any other budget alternatives to the uber expensive lenses out there? (outside of the afformentioned and DIY)
Thanks for all the time and info put into this forum, it is greatly appreciated and truly helpful,
-Richard
Old 07-22-08, 08:25 PM   #2 (Link)
Shack Helper
Alias: Prof.
Loc: South of Adelaide
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is offline
Re: A few Q's
CompguyRG wrote: View Post
Richard..The HTB lens is a very good unit from all reports and you couldn't do any better for the price..
Marks Aussiemorphic lens ( the one I use) is also an excellent lens for about the same price, but then you would have additional shipping charges...
If you've had a read through the "Making a DIY lens" thread in this forum and felt that you still can't make a lens yourself..then the HTB lens will fit the bill..
That shows it all pretty well..This is a site that I also have found handy when making a stretched cloth screen..This also shows the best order of stapling, to keep the cloth evenly stretched..
http://www.eldamar.net/house/ht/screenHowTo.html
None that I'm aware of..
Thanks for the compliment..
Let us know if we can help you any further..
Home Theatre....The never ending story!
Prof..
Old 07-23-08, 04:51 AM   #3 (Link)
Alias: Mark Techer
Loc: Brisbane, Australia
User: #15620
Since: Jan 2008
Mark Techer is online now
Re: A few Q's
Not really. Quality Optics cost money, pure and simple. The prisms, whilst they work, are not really optical grade as they can exhibit very small patches of non polished areas that, whilst invisible from the seating position, can and do prevent the true resolution of the fine detail of high definition video...
Mark
« Home Theater Shack > Home Theater | Audio and Video > Anamorphic Projection »
Similar Threads
Dual Sub Calibration Q's gary thomas REW Forum 4 12-15-07 02:31 PM
Rookie Q's on REW pbc REW Forum 9 11-26-07 04:00 PM
Some Q's on full range speakers BoomieMCT DIY Speakers 13 10-11-07 05:05 PM
Mach 5 Audio
