My New Projector - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Anamorphic Projection
My New Projector
Discuss My New Projector in the Home Theater | Audio and Video forum; My New Projector I thought I might share the news that I am now the proud owner of a BENQ W5000, true 1920 ...
Old 04-16-08, 09:28 AM   #1 (Link)
Alias: Mark Techer
Loc: Brisbane, Australia
User: #15620
Since: Jan 2008
Mark Techer is offline
My New Projector
I thought I might share the news that I am now the proud owner of a BENQ W5000, true 1920 x 1080 DLP with full scaling for CIH. I am finally able to enjoy stress free CIH HD video...
Mark
Old 04-16-08, 09:38 AM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Re: My New Porojector
Nice projector Mark! Anamorphic compatilble for a street price of $2500. How big are you projecting? Do you find the 1200 lumen rating bright enough?
We're all in this together!
Old 04-16-08, 04:08 PM   #3 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Congratulations Mark.... Describe!!!
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 04-16-08, 05:57 PM   #4 (Link)
Alias: Matt
User: #16260
Since: Jan 2008
mdrake is offline
Re: My New Projector
Congrats!! Will it do both Anamorphic and 16:9?
Old 04-16-08, 06:35 PM   #5 (Link)
Shack Helper
Alias: Prof.
Loc: South of Adelaide
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is online now
Mark Techer wrote: View Post
Mark
Ah!!..So the Benq won out Mark..
A very nice unit and with VS on HD..What else could one want!
I might have to hold off on the Optoma..It has a very short throw and very little zoom range which is going to make it difficult to mount in my situation..and probably won't have a good throw ratio..
I might have to save up some more bickies and look at the W5000...I am A Benq fan after all..
Some new screenies would be nice to see here..
Home Theatre....The never ending story!
Prof..
Old 04-17-08, 12:01 PM   #6 (Link)
Alias: Mark Techer
User: #15620
Since: Jan 2008
Naturally, I will run a page on my blog to the new set up soon, but I am just watching Transformers (SD) with the volume at -60 given it is 2:45 in the am
I have created a new room in a room for the house I am in now based on the one I had in my townhouse.
My screen is 2.37:1 at just 960mm high. The screen is an Oz Theatre Screen Majestic Scope with flocking and Acoustic Vision fabric instead of the normal EVO3D. But instead of the screen just being mounted, I have made a custom rig that allowed me to curve the screen for the compensation of pincusion caused by the anamorphic lens.
Unfortunately, I had to trash the beautiful flocked frame to curve it, but have since made a new frame (same size) from MDF that has been flocked with the same material. The reason I trashed the alloy frame is that I had to reverse the frame to hold tension when curving. I have since checked out Stewart and Screen Research, and yes, both have thier fabric attached at the front, then use a cover... You can read in depth about that on my site...
The new Benq W5000 is slick - very quiet and actually very bright. It has both dynamic iris (which I prefer not to use) and manual iris that I currently have set to 1 or the lowest postion, and trust me, if this image was any brighter, I would be uncomfortable watching. The good thing is, as the lamp dims, I can open the manual iris to let out more light...
If you read my site (blog), you will see that not only have I fully calibrated this projector, but also rana shootout with the W20000 as well.
Seating distances are close - front row is measure to be just 2x the image height and the raised back row is closer to 3x. I am sitting in the back row now and it great. I might just move to the front row for a while to see how it is.
WOW immersive, but still totally watchabe. This projector is truly like film, so you can sit at the same distances recommended for film by the SMPTE.
One thing I find when installing this tonight was that the unit will not allow 4x the image height was it is at about 3.5x at min zoom. Honestly, I feel that all projectors should allow at least 4x for mounting so that you can sit in a wide range of seating positions.
Yes, so anyway, I am liking this projector heaps look forward to upgrading to BD very soon...
My site is http://cavx.blogspot.com
Mark
Old 04-17-08, 12:58 PM   #7 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
I have made a custom rig that allowed me to curve the screen for the compensation of pincusion..........
Curved as in a "torus" screen?
Old 04-17-08, 08:01 PM   #8 (Link)
Shack Helper
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is online now
Mark..Why do you need a room within a room in your house.?
I understood the reasoning in your Town house, from the point of view of noise level..Do you have a similar problem now?
My screen is 2.37:1 at just 960mm high. Seating distances are close - front row is measure to be just 2x the image height and the raised back row is closer to 3x. I am sitting in the back row now and it great. I might just move to the front row for a while to see how it is.
Is that correct!!? 2x the image height!! That's only 6.5' from the screen..
My screen is 1M. high and I'm sitting at 9'6", and that's as close as I would like to be..
Admittedly your image would have better definition than mine, but all the same, I think that's very close in anyones language..
Prof..
Old 04-17-08, 11:30 PM   #9 (Link)
Alias: Mark Techer
User: #15620
Since: Jan 2008
Hi Mike,
No I ditched the Torus back in 06. I have just a curved scope screen - horizontal curve...
Hi Prof,
Yes and no. I don't really like to "advertise" the fact that my sound system can play as loud as 105dB per channel, so keep the level below about -10dB for most films. The main reason is the open floor plan of this house - there are no useable parallel wall for the surrounds, so I created my own tempory (and fully removeable) walls...
It is very close, but because of the high rez (it looks like film) it works. I sat in the front row during my post last night (actually this morning) for the rest of the film, and it is totally watchable, no pixels and clear , but your right, 3x is much better and where I sit when I go to a commercial cinema...
Mark
Old 04-18-08, 06:46 PM   #10 (Link)
Shack Helper
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is online now
Mark..Do you have any photos or drawings on how you did this?
Prof..
Old 04-19-08, 10:23 AM   #11 (Link)
Alias: Mark Techer
User: #15620
Since: Jan 2008
Prof. wrote: View Post
I do for the old place, but have documented this one. Basically, I have 3 sheets of MDF (2400mm x 1200mm x 16mm sheets) cut down to 1700mm x 1200mm and have used 75mm x 35mm kilm dried pine as the frame. I used metal shelf brackets to join the corners, so the two side and one rear can now free stand. The projector is on the rear wall and I will be modding that soon.
I have used batton screws to screw everything together, so no rattles and it is strong. Basically, the design allows me to install more panels as I need to. I have planned all screws and holes so that the install looks at least somewhat pro.
The rig is not painted yet, and I am actually contemplating using carpet here for both sound absorption and light control. The carpet can be rolled when I need to disassemble the rig to move to the next place.
Check out MY SITE to see what I did last time. The difference here is that I have been able to make the entry points at the front of the seating, so I have framing both at the top and bottom, so why it works and is very stable...
Mark
Old 04-20-08, 11:13 PM   #12 (Link)
Shack Helper
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is online now
Mark..I take it that you have some sort of acoustic treatment on those MDF panels.?
Otherwise I would imagine that it would produce a fair amount of resonance and standing waves within the three sides..
Prof..
Old 04-21-08, 10:04 AM   #13 (Link)
Alias: Mark Techer
User: #15620
Since: Jan 2008
I did have in the town house, but have not fitted them here yet...
Mark
Old 08-09-08, 09:59 PM   #14 (Link)
Alias: tmack
Loc: medina ohio
tbase1's Avatar
User: #3961
Since: Nov 2006
tbase1 is offline
what lens are you using?
Old 08-10-08, 03:57 AM   #15 (Link)
Alias: Mark Techer
User: #15620
Since: Jan 2008
Still the old 2 prism lens, but in the process of upgrading that to a fully corrected cylindrical lens...
Mark
Old 08-10-08, 07:51 PM   #16 (Link)
Shack Helper
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is online now
Mark..I'd love to see some photo's of that cylindrical lens when it's finished..
Prof..
Old 08-11-08, 02:26 AM   #17 (Link)
Alias: Mark Techer
User: #15620
Since: Jan 2008
You will There will be photos and screen shots (including sub pixels shots) everywhere...
Mark
« Home Theater Shack > Home Theater | Audio and Video > Anamorphic Projection »
Similar Threads
projector don5738 Home Theater Projectors 16 02-18-08 11:21 PM
new projector jwhite8086 Home Theater Projectors 4 12-09-07 02:20 PM
New to HT : Which Projector aod Home Theater Projectors 17 12-03-07 05:36 PM
How bright should a projector be? brandonnash Home Theater Projectors 7 10-19-07 04:59 PM
Projector selection robk_11 Home Theater Projectors 5 08-25-07 11:41 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray   Home
