| Anamorphic Projection FAO Mark Techer and others re screen ratioDiscuss FAO Mark Techer and others re screen ratio in the Home Theater | Audio and Video forum; FAO Mark Techer and others re screen ratio Hi Mark, and anyone else that can provide guidance.
My question is about screen sizes but is anamorphic related so ... |
Views: 525 - Replies: 4
| Hi Mark, and anyone else that can provide guidance. My question is about screen sizes but is anamorphic related so I am posting here rather than in the screen forum. I am making plans to get a scope screen and lens to go with my New JVC HD 750. With films being mainly 2.35 or 2.40 which ratio screen should I go for? It has to be electric, not fixed because for normal TV viewing my plasma is behind the screen. Initially after reading various posts on different forums I was considering 2.37 but would 2.40 be the best option along with some side masking for other ratios. I would appreciate your opinions and reasons for them. I also have some questions relating to screen type, and will post my questions on the screen forum. P.S Mark, What is the latest info on the Mk3 lens Thank you, Graham | ||||
| | #2 | ||||||
| Re: FAO Mark Techer and others re screen ratio Quote:
The MK3 is of course now CA corrected making it only the 3rd CA corrected HE prism based lens in the world. There will be a 5th element "CAVX CORRECTOR" in the coming months for astigmatism correction, but that is still under development... Mark | ||||||
| | #3 | ||||
| Re: FAO Mark Techer and others re screen ratio Hi Mark, thanks for your prompt reply, Graham I have been studying CIH for a while now before taking the plunge and have read many of your posts about it. I understand from one example you posted that most lenses are only focussed correctly in the horizontal and vertical planes within a set distance from the screen. Some questions on this. Does this mean that there will be a choice of CAVX Correctors for different distances? Is there a set distance that your lens works best at that negates the need for the corrector? I assume that the CAVX corrector can be retrofitted if required? Finally, do you have an estimate on the price of this addition? Thanks again, Graham | ||||
| | #4 | ||||||||
Mark | ||||||||
