Anamorphic Projection FAQ's DIY - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Anamorphic Projection
Discuss Anamorphic Projection FAQ's DIY in the Home Theater | Audio and Video forum; Anamorphic Projection FAQ's DIY Q. How do I make a DIY Anamorphic Projection set up? A. In reality, there are only three aspects to ...
 Closed Thread     Post New Thread
Old 01-21-08, 12:19 AM   #1 (Link)
Shack Helper
Alias: Prof.
Loc: South of Adelaide
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is online now
A. In reality, there are only three aspects to the DIY approach..The Lens..The lens Mount and the Screen..
LENSES:
You have two choices.
1. Buy a lens in kit form or partially assembled.
2. Buy the individual prisms, and make a box to hold them in position..
Lets start with the first option..
There are at least 2 individuals (no names given here) in the US and possibly more, and 1 in Australia, who will sell either a lens kit or a partially assembled lens..
They usually come with information on how to align the prisms and or the assembly of the unit..
The price you pay for this type of lens system, is far les than buying a commercial anamorphic lens..
The second option (and many have done this) is to buy your own prisms, make a box to hold them, and align the prisms yourself..
These prisms can be readily bought from Trophy Shops, sometimes online, or from individuals who will sell you a pair ready for mounting, but make sure that they are large enough..5"x7" being ideal..and that they don't have any engraving or other markings on them..
This is how easy it can be to set them up...
Several people have just placed their projector on a table or shelf, and just stand the prisms in front of the projector and angled them until they fill the 2.37:1 screen!..It's that easy..
Whilst they do get a Scope projected image, it's far from ideal, because the prisms will reflect light to the back and side walls..Also there is nothing to contain stray light fields, which will have a detrimental effect on the contrast of the projected image..
Like all lens systems, it's best to contain the optics in an enclosure that has a totally black, non reflective surface.
LENS MOUNTS:
There are numerous designs that have been made to hold the lens in place..
There are two types..FIXED and SLIDING..The latter may also be motorised with remote control..
Some have found (as I have) that they don't need a slide mount, and just rigidly mount the lens in front of the projector..
This means that all the aspect ratio's (with the exception of 1.33:1) are projected through the lens, and remain at virtually the same height for each..
On 1.78 and 1.85:1 images, you do lose a little definition, but barely noticeable, than if you had removed the lens and set the projector to the required format..But when you convert to an Anamorphic system, one tends to try and avoid these aspect ratio's as much as possible..
The other aspect of this is that if you watch all AR through the lens, you never have to reposition the lens..
If you do watch 1.33:1 movies, then a slide will be necessary to move the lens away..You may even have to re-position or use a higher screen with masking for the narrower AR's..which kind of defeats the purpose of CIH.. if your zoom control won't give you enough adjustment to reduce the height of the 1.33 image..
I actually have a slide mount, but I don't use it for the purpose it was intended..I have found it very useful for when I want to clean the lens..It's easier to clean it on a bench than up in the air, so I just slide it off the mount when cleaning is needed..
SCREENS:
Well I won't be going into all the various types of DIY screens that are out there...That's an individual choice..
Suffice to say that the screen aspect ratio should be 2.37- 2.40:1 for anamorphic projection..
The most common is 2.37, but some prefer to get the full width image when projecting 2.40:1 DVD's , but they generally are using some side masking for 2.35:1 movies..
Obviously, when you project 1.85 or 1.78 images, there are going to be black bars at the sides of the screen, but none top or bottom, so some prefer to have those bars masked anyway..
One very popular method of masking with CIH is the motorised, remote controlled curtain system, where you can stop the opening curtains at any point..
Others don't mind the black side bars, so they don't bother with any masking..
So, in a nutshell, this is all that's required to do your DIY side for Anamorphic Projection...
Home Theatre....The never ending story!
Prof..
Forum Rules
Old 01-28-08, 04:11 PM   #2 (Link)
Shack Helper
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is online now
Re: Anamorphic Projection FAQ's DIY
Q. What equipment do I need for CIH Projection..
A. That will depend on whether you are planning to use SD DVD's or HD DVD's..
SD DVD..
For SD DVD you have two choices..to keep it simple..
Firstly, if you haven't bought any equipment yet, then the choice is very simple..You just buy a Projector that has inbuilt vertical stretch..That's all you need..You can buy any SD or upscaling DVD player you like..
If you are converting to CIH and already have equipment, then the choices are limited to a degree.
If your current projector already has vertical stretch, then the above applies..
If your projector doesn't have the vertical stretch facility, then you will need a DVD player that has that facility..
Some of the Upscaling HD players have adjustment for vertical stretch..
HD DVD..
HD DVD hasn't really caught up with CIH users as yet and choices of equipment are limited..
Again, the simplest way is to buy a projector that has vertical stretch built in..
There are several brands on the current market that can do this, so you're sure to find a suitable projector..
HD DVD players with vertical stretch on the other hand, don't exist at the moment, which makes it difficult if your projector doesn't have that facility..
The only other choice is to buy an external scaler..This will do the required stretch, but they can be expensive..
Some people have opted to buy a new projector, rather than spend more on an external scaler, which when they upgrade their projector, they will have no further use for the scaler..
So that's it..All the equipment you will need with the lens and the CIH screen, to get you started into the world of Cinemascope..
Prof..
Forum Rules
« Home Theater Shack > Home Theater | Audio and Video > Anamorphic Projection »
Similar Threads
New Forum Now Open: Anamorphic Projection Sonnie Forum Announcements | News 0 01-18-08 05:08 PM
Trapezoids and anamorphic lenses John Simpson Home Theater Projectors 3 11-28-07 03:05 PM
Considering the 2.35:1 anamorphic upgrade? rwood01 Home Theater Projectors 24 04-12-07 06:52 PM
Denon 2800 and 16:9 anamorphic problems ccdoggy Home Theater Components 0 03-22-07 09:38 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
