Making A DIY Anamorphic Lens - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Anamorphic Projection
Discuss Making A DIY Anamorphic Lens in the Home Theater | Audio and Video forum; Making A DIY Anamorphic Lens If anyone has ever considered making their own lens, but felt it would be beyond their capabilities, this DIY article ...
Old 07-07-08, 08:01 PM   #1 (Link)
Shack Helper
Alias: Prof.
Loc: South of Adelaide
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is offline
If anyone has ever considered making their own lens, but felt it would be beyond their capabilities, this DIY article that was published sometime ago might just change your mind..
It's a very straight forward description of what's required to produce a very reasonable Anamorphic lens..
Anyone with any Carpentry skills should be able to make up the lens box..and the method of setting up the prisms is clearly explained and shown..
http://www.zuggsoft.com/theater/prism.htm
Home Theatre....The never ending story!
Prof..
Old 07-08-08, 08:03 PM   #2 (Link)
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
yourgrandma is offline
Re: Making A DIY Anamorphic Lens
I'd make one of those in a heartbeat, but the picture would be wider than the room. Sure would be nice to get extra screen size with no major degradation in picture quality.
Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3
Old 07-08-08, 09:14 PM   #3 (Link)
Shack Helper
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is offline
How wide is your room!!?
My theatre room is only 10'6" wide, but I have an 8' wide scope screen..
One of the advantages of scope screens is their low profile, which means you have more space to mount speakers above or below the screen, in narrow room situations..
Prof..
Old 07-08-08, 09:37 PM   #4 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is offline
Excellent article, Prof. I wonder if the bigger the prisms are the less pincushion effect there will be.
We're all in this together!
Old 07-08-08, 10:00 PM   #5 (Link)
Shack Helper
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is offline
Mike...Unfortunately no..
The only thing that affects pincushion is the throw ratio..The longer the throw ratio, the less pincushion effect..
The advantages of the larger prisms is that they can be used with a variety of projectors, and possibly help to collect maximum light output from the projector..
Prof..
Old 07-31-08, 01:41 AM   #6 (Link)
Alias: Mark Techer
Loc: Brisbane, Australia
User: #15620
Since: Jan 2008
Mark Techer is offline
Whilst the DIY lens has tradionally being a prisms lens, it may be possible to do (more difficult and expensive, none the less) to make a DIY cylindrical.
Anyone interested in discussing this?
Mark
Old 07-31-08, 02:01 AM   #7 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is offline
You have my attention. Are there any advantages to a cylindrical lens over a prism lens?
Old 07-31-08, 02:58 AM   #8 (Link)
Alias: Maverick
Loc: Sandnes, Norway
User: #7168
Since: Mar 2007
atledreier is offline
Definetly interested! This is intriguing. I like cheap DIY as long as it works.
My DIY build Status: Almost done.
My room thread
Old 07-31-08, 03:31 AM   #9 (Link)
Alias: Mark Techer
User: #15620
Since: Jan 2008
Many, including the ability to focus, which you can not do with prisms...
No, will not be cheap...
Mark
Old 07-31-08, 07:08 PM   #10 (Link)
Shack Helper
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is offline
Sounds very interesting Mark...
Are these cylindrical lens elements readily available?
Prof..
Old 08-02-08, 11:51 PM   #11 (Link)
Alias: Mark Techer
User: #15620
Since: Jan 2008
Prof. wrote: View Post
No. I am having them made to my specs. I have pricing and it makes a fully corrected cylindrical lens "affordable", but ultimately not cheap - still a couple of grand...but half the price of anything currently on the market in the same class...
Mark
Old 08-03-08, 06:54 PM   #12 (Link)
Shack Helper
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is offline
I presume that you would need a quantity of lens elements to be made up to keep the cost down..
Will it be a viable proposition considering the lack of interest that was shown towards the Mark 111 lens?
Prof..
Old 08-03-08, 10:21 PM   #13 (Link)
Alias: Mark Techer
User: #15620
Since: Jan 2008
This lens will not sell like the older prism lens, and the pricing I have been given are for a 1 off only. Only time will tell if this is viable enough to mass produce, but at least I end up with a new, fully performing anamorphic lens...
Mark
Old 08-04-08, 06:23 PM   #14 (Link)
Shack Helper
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
Prof. is offline
Well if I ever win the Lotto..I'll put in an order for one..
In the meantime I'm still very happy with the Mark 1..
Prof..
Old 08-04-08, 08:19 PM   #15 (Link)
Alias: Mark Techer
User: #15620
Since: Jan 2008
Yes, and I was happy too, then someone showed me better...
Mark
« Home Theater Shack > Home Theater | Audio and Video > Anamorphic Projection »
Similar Threads
Sanyo lens shift adjustment record_breaker Home Theater Projectors 2 02-15-08 09:52 PM
Vertical Lens Shift mitchok Home Theater Projectors 3 02-06-08 11:03 AM
Anamorphic Projection FAQ's DIY Prof. Anamorphic Projection 1 01-28-08 04:11 PM
Clean Projector lens safely????? alan monro Home Theater Projectors 1 06-16-07 08:26 PM
Sim2 shipping new CinemaScope lens for home cinema projectors Roger Home Theater, Audio and Video News 0 05-12-06 08:12 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116
