My Setup With Audyssey - Home Theater Forum and Systems -
post #1 of 10 Old 12-28-14, 06:13 AM Thread Starter
Hi all im new to this forum but not new to home theatre, i have owned now for a year my denon avr 3313, my reasion for joining this forum is to try and work out the setup of Audyssey, the past year i have reset and recalibrated the amp about 10 15 times and have learnt with every test.
My system is as follows.
Front L & R Sony ss-m500, 40-50.000 Hz Set to large
Centre Sony ss-cn250 85-20.000 Hz set to small
Surround L & R Eltax HT2 Bipolar 50-22.000 HZ set to small
Surround Back L&R Sony ss-sr250 85-20.000 HZ set to small
No sub at the moment
My issue has been levels especially the rears using audyssey the rears are always a little faint, but then using my sound level after improves things a lot more the clarity of sound directions, but i cant help think that Audyssey should make a better job of it than me manually doing it. Im very happy with the quality of sound, music is excellent and so are films but there some thing not quite right, when doing a setup the amp keeps showing out of phase for speakers centre and FR but i have checked the cable with meter from amp to speakers, but i will say some of the speakers Amit a slightly different ton with the test tone. I'm only using the rear seating area as the main listening area and using 6 positions with position 1 being in the centre of seat on a tripod above ear height. Ive uploaded some photos to show room layout and the levels calibration screen setting. the second photo is the level figures using my c- rated Sound meter. Any help greatly appreciated
Tonight in have done another speaker recal and gained better results with the souns stage, position one was as always centre, but the rest of the 5 postions i used spaceing of 1 ft max from the centre mark, postions 5-6 and placed thr rtipod right on the edge of the seat cusions, its now shown me just how finiky this multi xt really is.
PirateMark is offline
post #2 of 10 Old 12-28-14, 01:39 PM
HTS Senior Moderator
robbo266317's Avatar
Re: My Setup With Audyssey
Welcome to the forum Mark.
Silence is golden but duct tape is silver.
DIY completed:
robbo266317 is offline
post #3 of 10 Old 12-29-14, 10:41 AM
Things seem to make sense to me. Your surrounds are much closer to the mic than the fronts and therefore the trim levels are lower. The biggest change is in your center channel which my guess is because the measurement position was not exactly the same.
Your second approach of spacing the mic positions closer together is a good step. Beyond that, bump up or down the levels to appeal to your taste. Some movies/programs use the surrounds much more/less than others. Does your receiver have Audyssey Dynamic EQ? If so, enable that and you will notice boosted surrounds.
primetimeguy is offline
post #4 of 10 Old 12-29-14, 02:57 PM
tcarcio's Avatar
I don't know if you saw this but here is some great info on Audyssey posted by Wayne that will help...
Onkyo TX-NR809 HT receiver
HPS-4000,SR-70, John Allen, Klipsch Heresy, Speakers for L.C.R.
QSC GX-5 power amp for L+R mains
Chase Home Theater PRO-10's for surrounds
Behringer EP 4000 pro amp for the Danley DTS-10 tapped horn sub
Oppo BDP-93 universal BD player
Toshiba HD XA2 HD dvd player
Sony VW-VPLPRO1 1080p PJ
Cinema White 1.0 gain 106" fixed frame screen
Dish network with 2 Hoppers and 1 Joey
tcarcio is offline
post #5 of 10 Old 12-30-14, 09:09 AM
Very interesting setup.
What does the Audessey do if the projector screen is lowered?
The center channel height is probably aligned with the mic, the center speaker may also be more sensitive than the L/R speakers, the rug does not extend in front of the L/R speakers, or a combination of all that results in the -8dB for the center vs -4dB on the mains.
No subwoofer ?
chashint is offline
post #6 of 10 Old 12-30-14, 03:50 PM Thread Starter
Hi all
Have been and master reset the amp and using the same mic location the following levels have altered again
Front left -3.5
Front right -3.5
Centre -5-5
Surr left --2.5
Sur right -3.5
Surbck left-9.0
Surbck right -7.0
The main speakers give out out really good LFE so never really needed a sub, plus there not cheap any more to get a decent one,
The rug is just for show, I do have dynamic eq and its currently turned off,
When we use the the projector screen 125inch, we do loose volume from the fronts but sadly there not a lot we can do so just live with it.
I'll try and get some photos of the screen down.
post #7 of 10 Old 12-30-14, 04:23 PM Thread Starter
post #8 of 10 Old 12-30-14, 04:28 PM Thread Starter
post #9 of 10 Old 12-30-14, 04:32 PM Thread Starter
Main seating area
post #10 of 10 Old 12-30-14, 04:34 PM Thread Starter
My Setup With Audyssey-image-4105694076.jpg projector screen down for night viewing
audyssey , setup
