miniDSP DDRC-88A+BM Pre-Review Leak Thread - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
 7Likes
post #11 of 20 Old 08-10-16, 11:07 AM Thread Starter
HTS Moderator
Reviewer
AudiocRaver's Avatar
Wayne Myers
Re: miniDSP DDRC-88A+BM Pre-Review Leak Thread
Slow, slow, slow, but making progress. Had to get a handle on the interior gain structure of the 88BM and the best way to make use of it.
An apparent show-stopper for a few potential Dirac users has been: "What happened to my gain? I can't get it loud enough." I hope to have an answer to this issue.
Also working on a checklist for 88BM implementation.
ellisr63 likes this.
AudiocRaver is offline
post #12 of 20 Old 08-11-16, 06:51 AM
FargateOne's Avatar
Can I suggest an other question? Is the sound very different (measurable differences ? maybe??) than with NanoAVR-DL for small to medium size rooms?
FargateOne is offline
post #13 of 20 Old 08-11-16, 06:54 AM Thread Starter
HTS Moderator
Reviewer
Wayne Myers
Very good question, I will try to squeeze in an AB comparison.
post #14 of 20 Old 08-12-16, 09:35 AM
FargateOne's Avatar
AudiocRaver wrote: View Post
That would be great for many of us. I do not know all the science between the "before and after bass management thing", but my intuition tells me that there is no such a great difference in rooms, let us say, less than
2 000ish cube feet.
post #15 of 20 Old 09-29-16, 07:52 PM
ellisr63's Avatar
Ron
Have you by any chance tried running the Dirac Setup with the mic pattern being real close vs a wide pattern? I am asking this because in my room a single point tune had unreal mid to high clarity, and when we did a pattern that went to the center of the seat on each side of the MLP seat the mids to high are not near as clear as they were with the single mic position. I am assuming this is because Dirac is trying to average the sound over a larger area.
I am going to try this weekend to do a 2nd tune that is in a closer grouping that would not extend beyond my MLP seat and see if it brings back the clarity from the single mic tune. I am very curious to see what it does on your setup too. I am hoping it does bring back the clarity as it will be excellent for 2 channel listening too then.
Ron
My Home Theater
ellisr63 is online now
post #16 of 20 Old 10-02-16, 07:52 AM Thread Starter
HTS Moderator
Reviewer
Wayne Myers
The review has been posted.
ellisr63 wrote: View Post
I have seen that tendency. I actually did a fair amount of listening with a 3-point pattern, MLP, 1 foot forward, another 1 foot forward. Sounded fantastic. 3 points helps negate effects from chair back reflections.
Not recommending it over DL's way, because their pattern gives terrific results, too. But it is sure worth a try. Plus, with DL, if you don't like it, you don't have to start over, just add more measurements and re-optimize.
post #17 of 20 Old 10-02-16, 10:37 PM Thread Starter
HTS Moderator
Reviewer
Wayne Myers
BTW, other than the MLP 1st mic position, no precise position measuring was used for any other points, all were eyeballed. I have never needed to be more careful than that with Dirac Live.
The MIP 1st mic position, however, I measure with laser distance meter and with analog mic / audio interface / timing loopback, as a reference, to verify precise equidistance from each of the front mains & front wall. I saved Measurement 1 as a project of its own so I could quickly and easily add whatever measurements I wanted to without having to repeat it.
post #18 of 20 Old 12-23-16, 11:25 PM
RTS100x5's Avatar
RTS100x5
Don't upgrade the firmware to the new one that just came out...people are having problems with it connecting afterwards.
Ive had my unit now for 2 months - it started generating random crackling / popping sounds and Im not the only one with this issue.... no issues with connection
but imagine loud random popping sounds like capacitor discharge...
Its definitely not the gain structure being over driven OR sweeps recorded too high / gain....
Its soon to be a deal breaker.... at least 2 others on forum reporting similar issue....
AVR - MARANTZ 7702 w PANGEA AC14
AMP - EMOTIVA XPA7 w PANGEA AC9
DISPLAY - EPSON 5040 / 120in DIY SCREEN w BEHR SILVER SCREEN
MAINS + SURROUND - DIY w DAYTON PT2C-8 PLANAR MID/HIGHS + DAYTON 9" MIDBASS -
SUBS - (2) DAYTON 15" ULTIMAX
SUB AMP -CROWN XLS2502
BLURAY -SAMSUNG UBD K8500
HTPC - HALO CLARO + EXT CARD w BURSON 5th GEN. DISCREET OPAMPS,
RTS100x5 is offline
post #19 of 20 Old 12-24-16, 01:40 PM
ellisr63's Avatar
Ron
RTS100x5 wrote: View Post
Mine is working fine other than one channel emitting a buzz. We believe it is caused by the hookup blocks, as the weight of the cables has made them seem loose. I chatted with MiniDSP, and they wanted me to send it back at my expense. For the time being we have moved the problem channel to the surrounds so it is not heard unless you are almost next to the speaker. Eventually i will have a friend check the solder joints on the board where the connectors attach, as we think it is a bad solder joint causing our problem.
Ron
My Home Theater
post #20 of 20 Old 12-27-16, 10:31 PM Thread Starter
HTS Moderator
Reviewer
Wayne Myers
Weird. Always, always, always provide strain relief.
It does kinda sound like a bad ground. Try a short jumper from a neighboring ground pin to the ground pin of the noisy channel, on the outside of the unit, you don't even have to crack the cover open, see if it eliminates the buzz. It might save your DDRC-88BM a return trip to Hong Kong.
bm , ddrc88a , leak , minidsp , prereview , thread
