Recieved my unit back in NOV and immediately upgraded to latest Firmware... from day 1 its been generating crackling sounds - like capacitor discharge
Before you comment I assure you its NOT a gain/over drive issue .I have repeatedly set gains in the sweep/measuring process lower and lower / no help...
Its random channels even sometimes with audio muted... several others on minidsp forum have also reported this issue. support sent me a firmware revision but it did nothing to fix the issue..
I need others who have a similar issue to chime in with possible fixes - even if you have a different model DL processor .....
Maybe its setup related - mine is XLR in/out to my Emotiva amp
all sources - hdmi and analog 7.1 in are affected
totally random times and channels
I grounded my new Omnimount rack last night thinking it might be a static charge but that did not help either
I have requested an RA at this point and when I have to pay for return shipping to HK Im going to be HIGHLY "MAD"
Wow, not quite sure what to suggest. The demo unit I was sent for review has behaved perfectly. I am aware there is a firmware upgrade and have shied away from doing it for now because it did not appear to be needed and I did not want to get into trouble fixing something that was "not broke." I tend to shy from firmware upgrades in general unless a known problem is being addressed and I expect to experience improvement by applying it. Chicken, I guess. I bricked a perfectly good router a year ago with such an upgrade, and a printer, too, swore I would not apply another without good reason.
I have not had any trouble with any equipment miniDSP has sent me. I understand also that diagnosing via internet/phone/logs is difficult, getting the unit into their hands gives them max chance of figuring out any issues for you and for the rest of us and future customers. I understand your frustration, though.
UPDATE - Before sending my unit back to HK I thought I would give it one more chance with a new sweep measurement ,,, While setting the mic up it occured to me that although DevTeam had sent me a beta FW file - I had not made any new sweep measurements with that FW
STUPID ME --- I was still using the OLD config file ,,,,
As of 3 hours ago having made a new config measurement I have NOT heard a single pop sound from any channel !!!!
Trying not to get too excited too fast but so far its night and day !!!! NO POPPING SOUNDS
I did notice something during this calibration setup... Once the mic/gain level was set to just below -24db, if I let it sit there after about 1 minute the level rose to about 3-4db above -24.... obviously nothing in my room is getting louder so I did reduce the mic/gain level to compensate for this and ran an new sweep...
NOW I have NO POPPING SOUNDS !! Im so relieved !!!!
A note on the DL calibration levels. The level bars on the Levels page can be changed by the mouse scroll wheel (apologies if you already know this). That can be really handy, but can also get you thinking there are some Tiny Demons (listen to the song by Todd Rundgren - bonus track on his Healing album).in your system. Any possibility that is the cause of the mic gain change?
Well this week my popping noises returned with a vengeance ... I mean I was about to rip the DIRAC unit out of my rack and toss it to the curb .... I had repeatedly gone through the protocol of setting it up properly and thought I had it under control ... I had added additional curtains to my media room this week and thought I would risk taking a new measurement....well it all fell into the popping abyss again so I just started checking XLR cables and tightening this phoenix and tweaking that level - I even suspected the USB driver in my HTPC at one point ...The only common denominator that I had never suspected was my new HT OMEGA XT sound card in my HTPC (a $700 combo with Burson Opamps) ... It was like the scene from French Connection where the mechanic is tearing the car apart looking for the dope... he finally says "Listen I checked everything in the car.............except the rocker panels" DOHHHH
Well long story short version I switched over to my AMD HDMI driver for sound and WHAMMO - NOISE FREE SOUND.... I was really unaware that the AMD driver supports mutichannel @ 192k :surprise:
The sad part is my HALO XT sound card is 2 months out of warranty..... Since I have so much invested in the Opamps I may eat the $200 and get a replacement - its really and unbeatable sound quality when it's working properly ....
So Im kinda back in DIRAC Multichannel BLISS with my new system ...... now do I call HT OMEGA and see if they will fix my sound card or just get another one and get on with it ....
The only question I would ask is: Does that card make the popping noise only when it is connected with the DDRC88, or does it do it regardless of what it is talking to? IOW, is there a synergy involved between those two pieces of hardware. or is it the Omega alone that creates the noise no matter what?
I did not take the time to isolate the card in that way since switching to the HDMI driver in the same computer fixed the issue I was having... Sound card is under RMA....
Even after I switched to HDMI audio , the popping sounds have come back - usually about 45 minutes into whatever Im listening to ... leading me to believe its a heat related issue... Im putting fans on mu unit before I ship this back to HK....
I was asked to ship my unit back to Hong Kong for evaluation .... shipping to HK at my expense... the unit is well within warranty coverage...
If your not familiar with these issue - especially after making any Dirac calibration I get random crackling pops at loud volume - unplugging the unit once -sometimes several times is necessary to temporarily fix this issue... It is obviously very distressing to be listening to music at mid level and all of a sudden the loud popping sounds start happening... Quite a few people have reported this issue on MiniDSP forum with absolutely the same issue - Tech support has been pathetically slow in addressing this issue - mostly presuming that the customer has incorrectly setup the unit or is incorrectly using the calibration setup...
Now they want me to ship my unit back at my expense - my thoughts on that policy cannot be written here.... Tech support is bad enough that it is ONLY email response... the fact that they seem to have no answer to this issue (which was actually an identical problem with the first Emotiva/XMC1 units) is not acceptable... When my DDRC88BM works correctly it's fantastic - absolutely addicted to the performance and impulse response correction method... when it fails Im pulling my hair out...:rant:
Related Threads
742.3K posts
170.9K members
Since 2006
