jmschnur wrote:
Not clear on how the rear monopoles should be phased location is as you have drawn.
S |
All speakers should be wired in-phase.
If the Back Surrounds are monopoles (direct radiators), then you mount them on the back wall so they fire right at the screen.
Is your system THX by chance? If not, does not matter. THX (ULTRA 2) use mono poles placed together on the back wall. You can spread them apart for better separation of the back surrounds for 7.1 program if you want.
