BFD | Electronic Equalization DevicesDiscuss FBQ 2496 Dj setup help. in the Equalization | Calibration forum; FBQ 2496 Dj setup help. I just purchase a fbq2496 for my dj sound system. It will be connected to my low sub for feedback ... |
Views: 1166 - Replies: 11
| FBQ 2496 Dj setup help. I just purchase a fbq2496 for my dj sound system. It will be connected to my low sub for feedback problem. I need some help on programming it. I would like to use the parametric eq 30 - 90 hz for bass boost with feedback destroying for my mic stage at live events. Could you give me some help on how to program the fbq2496. The 2496 is connected to my mixer sub out and my low sub crossover. How do i set the filter to a 6db boost 30 - 90 hz and use it also as a feedback destroyer. Thanks, note this is used strictly on low subs. | ||||
| | #2 | ||||
| Re: FBQ 2496 Dj setup help. Howdy don and welcome to the Shack. It sounds like maybe you will want to look over the BFD Guide. Trying to teach you how to program it in a forum thread will be a real challenge. The Guide should help you fine with the boosting part (see page two - Manual Method), but as far as the feedback, I would simply follow the provided manual instructions for that. I am not sure you can do both at one time. | ||||
| | #3 | ||||
| Re: FBQ 2496 Dj setup help. Hi Don, With the FBQ connected to your mixer’s sub out, you won’t be able to do both sub EQ and feedback eliminating (at least, none above the crossover frequency). To do both, you would have to connect the EQ in front of your crossover. Naturally, any 30-90 Hz boost you do with it connected like that will affect the main speakers as well as the subs. Another option, if your mixer has an insert for the mic channel, you could patch one channel of the FBQ there, and use the other channel for the sub out, as you have done now. Also, when you say you want to boost between 30-90 Hz, that’s pretty much the full range of the sub, isn’t it? Why not just turn the sub up? Regards, Wayne | ||||
| | #4 | ||||
| Re: FBQ 2496 Dj setup help. Thanks for the replies. I dj parties my fbq is only use for the sub, not mains, Is it possible to use 1 filter for peq set to 80 hz and use the other filters for single shot or auto filter. My rig is setup for 4 way highs, mid, low mid,& sub. High to low mid is feed from my main to a dbx driverack PA and and my sub to the fbq. Last edited by mrbombastic; 03-14-08 at 11:48 AM.. Reason: additional info | ||||
| | #5 | |||||
| Re: FBQ 2496 Dj setup help. Quote:
Doesn’t the driverack have parametric equalizing? You could use that to take care of your feedback problem w/o inserting another processor in your main-channel signal chain. Regards, Wayne | |||||
| | #7 | ||||
| Re: FBQ 2496 Dj setup help. If that’s the way you intend to keep the FBQ connected, then no you can’t use it for feedback control. Unless you’re having low frequency feedback. Regards, Wayne | ||||
| | #9 | ||||
| Re: FBQ 2496 Dj setup help. Have you tried turning down the bass in your mic? Or engaging the high pass filter on that channel of the mixer? Regards, Wayne | ||||
| | #10 | ||||
| Re: FBQ 2496 Dj setup help. When i turn down the bass on the mic channel down, the mic sounds thinny, the trouble is i get these bass feedback when i play in small compact spaces. I thank you for all the info Last edited by mrbombastic; 03-14-08 at 01:23 PM.. Reason: correction | ||||
