| BFD | Electronic Equalization Devices Newbie: BFD not turning onDiscuss Newbie: BFD not turning on in the Equalization | Calibration forum; Newbie: BFD not turning on Hi
I got the 1124P a few months ago, but never got to set it up. Finally got time this ... |
Views: 445 - Replies: 6
| Newbie: BFD not turning on Hi I got the 1124P a few months ago, but never got to set it up. Finally got time this weekend to try it out. I made all the connections and started the calibrations yesterday (Saturday). When I went back this morning to continue the calibrations, I noticed that the power switch was on. I turned it off and then on, but it won't turn on again. I hear the pop in the SW, so it seems to be getting power, but the LED won't come on. Did I kill it by keeping it on last night or am I missing something? Thanks - Anil. | ||||
| | #2 | ||||||
| Re: Newbie: BFD not turning on Quote:
Sounds like a fault. Can you return it? brucek | ||||||
| | #4 | |||||
brucek | |||||
| | #6 | ||||
| Re: Newbie: BFD not turning on I had the same problem with the one I received. Actually - it powers on sometimes, and after sitting for a couple minutes/seconds powers off and then wont come on for a while. I noticed that shaking it/turning it around and upside down did produce a blip of power. Maybe it is just a faulty connection. Did you get a chance to try that yet? If it works let me know, I'll crack mine open instead of sending it back. On that note, B&H has been great in the RMA process, I just havent sent it yet. I figure I won't if I don't need to maybe ![]() | ||||
| | #7 | ||||
| Re: Newbie: BFD not turning on Hi Bruckek, I opened the top cover. The front panel connectors are real tight and there is not much room there to use your hand to pull it out and re-seat it. So I just used a finger to push all the connectors both on the display and the circuit board. Put the plug in and the display sprang to life. So it seems to be some loose connection somewhere. Thanks for the pointer! Maxx - you should try the same and see if it works. - Anil. | ||||
