| BFD | Electronic Equalization Devices BFD HUMDiscuss BFD HUM in the Equalization | Calibration forum; BFD HUM I dont get any hum when the I connect the BFD to the subwoofer.
Amp->BFD connected by RCA to XLR
Views: 625 - Replies: 14
| BFD HUM I dont get any hum when the I connect the BFD to the subwoofer. Amp->BFD connected by RCA to XLR BFD->Sub connected by XLR to RCA Used the interconnect guide from rane http://www.rane.com/note110.html to do the interconnects. When everything is connected, there is no hum from the sub. When I play either music or movies the sub hums . When watching movies especially during a quiet scene I can cleary hear the hum from the sub. If I switch off the BFD and turn it back on the hum disappears. All the components are connect to belkin PF60 power console.I dont know what else to do ![]() | ||||
| | #3 | ||||
| Re: BFD HUM My apologies bruce. 2 conductor shielded cable ( BELDENŽ 1800B) for the interconnect from http://www.rane.com/note110.html AMP- BFD followed #17 RCA-> XLR BFD->SUB followed #6 XLR->RCA female + DIY 'Y' connector(using BELDENŽ 1855A cable and gold plated RCA connector) into the sub | ||||
| | #5 | ||||
| Re: BFD HUM yes I have shorted pin 3 and 1 | ||||
| | #6 | ||||
| Re: BFD HUM This connects the AC ground of the BFD itself to the BFD's output of its negative differential amplifer. This ground then passes on the black wire to the outer case of the RCA at the other end, which in turn is the AC/DC ground of the sub. It would be wise to remove this connection from pin 1 to pin 3, and you will then break that un-needed possibility for a ground loop. This will then be equal to the situation you have with your input cable. It will preserve the floating nature of both the plus and minus input and output differential amplifiers in the BFD. The shields are still connected to case (pin 1) in both situations, but no connection is made with the external source or sink device. The devices themselves are safe since you have not interfered with the third prong safety ground on the AC plug of any device. Anyway, give that a try and see if it helps. If that's the source, it will clear it. If not, it won't..... brucek. | ||||
| | #7 | ||||
| Re: BFD HUM I did have the short removed but made no difference. The hum is there if I play a movie at around -35db level on the receiver. When I switch on all the equipment there is no hum. Btw I have a pioneer 2016AVS receiver if that is of any help. Thanks for the help bruce. | ||||
| | #8 | |||||||
| Re: BFD HUM Quote:
I guess you must know how very unusual those quotes I listed appear...... Do you happen to have a rather large gain filter in the BFD that is exacerbating a hum that already exists in the source equipment? Have you removed the BFD and listened real hard for the hum at any level? Have you temporarily tried a cheater plug on the BFD? Does your receiver have any sort of Auto-EQ system that is on? brucek | |||||||
| | #9 | |||||||
| Re: BFD HUM Quote:
even after turning off the amp the hum still persists. When I turn on all the components there is no hum ![]() I did notice that if I do a mono connection the hum reduces. If i connect in stereo the hum is more pronounced. Last edited by rudra; 06-05-08 at 05:38 AM.. Reason: forgot 2 add info | |||||||
| | #11 | ||||
| Re: BFD HUM I dont have cable TV. I do have a sat installed. Disconnecting it does not make any difference. ![]() | ||||
| | #13 | ||||
| Re: BFD HUM I have been busy. Got a chance to look at the problem in the weekend. You were right It is a BFD filter issue. When I bypass the BFD the hum is not there. I will have to see what filter setting in particular is causing it. What would be the best to approach the problem. I dont have the filter files with me. | ||||
| | #14 | |||||
| Re: BFD HUM Quote:
Generally with a BFD you select a program slot for your filters (i.e. #4), and set all the 12 filters in both channels to OF mode. This ensures you don't inadvertently have one filter set to feedback destroy. Then one by one you add the filters you need by placing it in PA mode (parametric) and set the parameters for that filter. If you've done this already and you have a strange hum, then simply turn each PA mode filter to OF mode until the hum goes away. Then decide why the hum is happening with that filter (i.e. gain too high, etc.) brucek | |||||
| | #15 | ||||
| Re: BFD HUM The filters were set by REW. I will try what you suggested and will let you know how it goes | ||||
