Epik Knight
Discuss Epik Knight in the Equalization | Calibration forum; Epik Knight What should I do, I got my Epik Knight last week , but we also had soggy carpets from 11+ ...
Views: 717 - Replies: 6
Old 06-18-08, 12:21 PM   #1
SRR
Alias: Tim
User: #20375
Since: May 2008
  SRR is offline
Epik Knight
What should I do, I got my Epik Knight last week , but we also had soggy carpets from 11+ inches of rain , well that is not my point...
Anyways it is dry now, sub is in position, about the only place it can go. And well take a look:
That is with three measure points averaged. Taken with a DBX RTA-M mic, nice preamp, nice sound card, etc. BUT, with out the Behringer doing its thing. That is just Audyssey. I know I have a lot of extra stuff at 70-80Hz. But is that a evil thing? Should I keep the Behringer 1124 that I have for just one filter maybe two?
Old 06-18-08, 12:27 PM   #2
SRR
Alias: Tim
User: #20375
Since: May 2008
  SRR is offline
Re: Epik Knight
Here is another look at it.
Purple is before Audyssey from main position, Blue is after Audyssey main position, and Green is Average of three positions.
Old 06-18-08, 12:31 PM   #3
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: Epik Knight
What, no house curve?
I assume you had a calibration file for the mic?
The 70-80 Hz thing might be audible. I suggest applying a filter with the BFD and listening to it both ways.
Old 06-18-08, 12:57 PM   #4
SRR
Alias: Tim
User: #20375
Since: May 2008
  SRR is offline
Re: Epik Knight
Ya I had made up my own house curve, but with it looking almost good enough as is without a curve...well....ya know...ummm...
And yes I have the calibration file for the soundcard, it is just not shown.
I did apply what REW suggested for a filter at 70 something, last night and I am not sure if it was all that better or not. Wasn't worse, per say, but better .
I guess I need to do some more listening, with the Behringer engaged and not engaged.
Old 06-18-08, 03:08 PM   #5
Alias: Wayne
Loc: Katy, Texas
User: #8
Re: Epik Knight
SRR wrote: View Post
As I noted, you need a calibration file for the mic as well.
Old 06-18-08, 03:09 PM   #6
SRR
Alias: Tim
User: #20375
Since: May 2008
  SRR is offline
Re: Epik Knight
Do you have the calibration file for the DBX mic?
Old 06-18-08, 03:18 PM   #7
Alias: Wayne
Loc: Katy, Texas
User: #8
Re: Epik Knight
Nope. It's easy enough to create one if you can get a frequency response graph from dbx.
