| BFD | Electronic Equalization Devices Obvious nooby questionDiscuss Obvious nooby question in the Equalization | Calibration forum; Obvious nooby question first, Thank you to those genuises that put together REW and BFD guide so that we can all have access ... |
Views: 352 - Replies: 4
| Obvious nooby question first, Thank you to those genuises that put together REW and BFD guide so that we can all have access to them. ![]() I have done my measurments, applied the filters in bfd and made sure the in/out is not flashing and when I measure to see the difference I get the same measurements. Am I missing something simple? ![]() Thanks, Henry | ||||
| | #4 | ||||
| Re: Obvious nooby question Well, as long as the IN/OUT LED is solid green, then those filters are enabled. The best way to check out if all is working OK, is to use REW to generate a single sine wave at 50Hz (for example), and turn on the sub so you can hear that tone, then enter a filter at 50Hz into the BFD front panel and play around with the gain of that filter. Turn the gain a large negative and hear the tone go away, and then turn it up and hear the tone get loud. Use that as your test tool.. brucek | ||||
| | #5 | |||||
| Re: Obvious nooby question Quote:
Thanks again, Henry | |||||
