BFD needed with SVS PB13-Ultra???
Discuss BFD needed with SVS PB13-Ultra??? in the Equalization | Calibration forum; BFD needed with SVS PB13-Ultra??? I remember reading on the forums somewhere that the SVS PB13-Ultra has some sort of ''Tunability'' to it. Is the ...
Views: 579 - Replies: 6
Old 07-15-08, 02:04 PM   #1
Alias: sollars
Loc: Kansas City, Missouri
User: #19719
Since: Apr 2008
  mrsollars is offline
Is the capability going to do the same thing as leveling the FR like a BFD does?
I'm completely new to this. Saving up for the pb13 and SCS' fronts, sbs surrounds. couple of months out.
let me know...thanks.
matt
Old 07-15-08, 02:09 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: BFD needed with SVS PB13-Ultra???
In most cases the PB13 ultra should have enough control on it to get it sounding the way you want without a BFD.
The back plate amp built by Bash seen below has lots of adjustments.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 07-15-08, 09:02 PM   #3
Alias: mike
mike c's Avatar
User: #147
  mike c is offline
the ultra has a ONE band PEQ.
the BFD pretty much has a million bands of PEQ ...
i find that I still use all 8 PEQ bands of my SMS-1 to "really" flatten the frequency response
Old 07-15-08, 10:21 PM   #4
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
mrsollars wrote: View Post
let me know...thanks. matt
I think that will depend on your room frequency response
If you have a lot of peaks and nulls in your response, but you have a receiver with a parametric equalizer and your PB13 is also capable of fine tuning the response ... maybe it will be enough to adjust the results
I'm sure is not the same as using a BFD ... but if you can accomplish the same results without one; Why spend money on one
There's a member who has a SVS sub (PB12 I think) ... he measured the room response, corrected a peak he had and he is waiting for his new receiver to adjust the rest (his current receiver doen't have PEQ), he is happy with the results and maybe he won't need a BFD at all
Old 07-15-08, 10:29 PM   #5
Alias: Tim
OvalNut's Avatar
Loc: North of Atlanta, GA
User: #1625
  OvalNut is offline
I have a PC13 Ultra, and use a FBQ2496 (BFD cousin) for the fully parametric capability to dial in the response. The Ultra can only do one PEQ cut + adjust the low end roll off and tuning point. Once you've used a program like REW together with a parametric equalizer on the subwoofer channel, you'll probably not want to give up that level of tuning capability. It's really pretty amazing.
Tim
He drove a black and white pirate ship at 190 mph.
- Dale in the #3 will never be forgotten. Thanks for the memories.
Old 07-16-08, 02:58 AM   #6
Alias: sollars
User: #19719
Since: Apr 2008
my reciever is the yamaha rx-v663. not sure of it's capabilities for this.
i'm also not sure if i will need to use the BFD. but i guess i'll just wait until it's all up and running.
question.....why is the BFQ2496 considered the ''cousin'' of the BFD. (i thought that WAS the BFD...just the newest version of it) What Behringer product SHOULD i be getting if i feel i need one.
thanks matt
Old 07-16-08, 07:38 AM   #7
Alias: Tim
OvalNut's Avatar
User: #1625
  OvalNut is offline
I just referred to the FBQ2496 as a "cousin", though you are correct, it is the newer version BFD.
Tim
needed, pb13-ultra???
