| BFD | Electronic Equalization Devices Hum ProblemDiscuss Hum Problem in the Equalization | Calibration forum; Hum Problem Well like most everyone else i have a hum. I did purchase a cheater plug and it is much better. ... |
Views: 358 - Replies: 3
| Hum Problem Well like most everyone else i have a hum. I did purchase a cheater plug and it is much better. I know it is not a permanite solution so i ordered a DCI ALH1A. When I hook it up i makes a really large BUZZ My sub is at the back of the room away from my Media Center. I have run it at the sub and i have run it right after the FBQ 2496.I have also put in a call to DCI to call me back on this issue. Please Advise ![]() Thanks | ||||
| | #2 | ||||||
| Re: Hum Problem Welcome to the club ... I got the famous Hum after I connected my Buttkicker amp ![]() Quote:
![]() Quote:
| | #4 | ||||
| Re: Hum Problem Yeah, I don't have a lot of confidence in the DC1. Never tried one, but the theory seems dubious. Anyway, if the cheater worked, then you'd probably have better luck with a HumX. Have you tried making up a cable that helps to break the loop. See the hum thread. brucek | ||||
