BFD | Electronic Equalization DevicesDiscuss BFD Sub Pop/Thump While Idle in the Equalization | Calibration forum; BFD Sub Pop/Thump While Idle I just connected my BFD 1124 Firmware v1.0. I have been leaving the BFD always on, and my sub is ... |
Views: 792 - Replies: 3
| BFD Sub Pop/Thump While Idle I just connected my BFD 1124 Firmware v1.0. I have been leaving the BFD always on, and my sub is set to 'auto' to turn on when a signal is received. When everything else is turned off, I've noticed that every 5-10 minutes or so, while the sub is in stand-by, the subwoofer will make a single loud 'thump'. The same kind of sound it makes when I turn on the BFD while the sub is 'on'. If I turn the BFD off when not in use (sub still in 'auto'), it doesn't do this. Does the BFD send a periodic signal to the sub or something that may cause it to wake out of stand-by mode and 'thump'? PS, I also have the 'hum' issue, which I'm going to take care of via suggestions from the forum. Are these related? Has anyone else seen this? | ||||
| | #2 | ||||||
| Re: BFD Sub Pop/Thump While Idle Quote:
Also try a cheater as a test for a while (assuming that removes the hum) and see if the problem goes away. brucek | ||||||
| | #4 | ||||
| Re: BFD Sub Pop/Thump While Idle Just remember that a cheater plug was to make the test only ... you need to get a ground isolator to permanently fix the "hum" problem ... I read that is not safe to use a cheater plug to permanently fix a "hum" ![]() | ||||
