Preamp: Digital in + digital out "tape loop?"
Discuss Preamp: Digital in + digital out "tape loop?" in the Equalization | Calibration forum; Preamp: Digital in + digital out "tape loop?" Hi Guys: I am upgrading my pre/power amps and hope to smoothly integrate the DEQ2496 for 2.1 channel use. I ...
Views: 480 - Replies: 5
Old 08-07-08, 02:19 AM   #1
Alias: spreston
Loc: nyc
User: #21009
Since: May 2008
  spreston is offline
Hi Guys:
I am looking to utilize the DA processor of the preamp for all sources and bypass the DEQ's DA processor by
* using the DEQ's digital in/digital out connections (and corresponding digital in/digital out connections from preamp, acting like a digital "tape loop")
* not using the analog tape in/tape out to connect the DEQ (my current method)
I just looked at a Sunfire TG2 which has a well rated DA processor. But Sunfire customer support confirmed that despite having digital in and digital out connections, I could not set up a digital in/digital out "tape loop."
Are there any preamps that will allow me to set up a digital "tape loop" and avoid purchasing yet another DA converter? How have others dealt with DA conversion on the Behringers?
Thanks,
:p
Old 08-08-08, 10:41 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Preamp: Digital in + digital out "tape loop?"
I don't ever recall seeing such a thing.
Old 08-08-08, 11:06 AM   #3
Alias: spreston
Loc: nyc
User: #21009
Since: May 2008
  spreston is offline
Strange; seems such a waste not to make DA conversion fully available to enduser.
Could that be possibly related to digital rights protection of CDs and DVDs?
Old 08-08-08, 11:39 AM   #4
Alias: brucek
User: #6
Think about what you're asking them to do.
All the digital SPDIF inputs to a processor are sent to a switcher and then decoded (PCM, DTS, AC-3, etc) and processed into their respective types and multi-channels. All these digital channels (7?) are then finally sent to DACs to turn them into analog for further level control and output.
You want the manufacturer to break out all those digital signals before the DAC's and process them through SPDIF transmitters and make them avalable as output jacks in SPDIF, and then provide the same number of digital loop inputs that require converting from SPDIF so the DAC's can receive the signals.
I just don't know of any processor that offers that. It would have very limited appeal to most people, so they don't waste costs on that feature.
Old 08-08-08, 05:33 PM   #5
Alias: spreston
Loc: nyc
User: #21009
Since: May 2008
  spreston is offline
I am thinking a bit simpler 2 channel functionality.
Digital in/out would be useful for those with CD or DAT units which have both playback and record functions...
Old 08-08-08, 06:14 PM   #6
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
The problem is that A/V receivers and processors with digital record loops for CDR or DAT don’t have them switched like the analog tape loops of old. So, you have no access to the loop for utilizing and inserting a global processor. You would only be processing the record loop itself, for the purposes of the digital recorder...
"tape, digital, loop?", preamp:
