Multiple BFQ2496 patched together?
Discuss Multiple BFQ2496 patched together? in the Equalization | Calibration forum; Multiple BFQ2496 patched together? Is it possible to use the BFQ2496 in groups patched in loop configuration to control each frequency band though to ...
Views: 295 - Replies: 5
Old 10-12-08, 03:05 PM   #1
Alias: andy summers
Andysu's Avatar
Loc: United Kingdom
User: #20513
Since: May 2008
  Andysu is offline
Is it possible to use the BFQ2496 in groups patched in loop configuration to control each frequency band though to the cut-off point on the crossover? Would using the narrow filters of the Q result in ultra flat response?
1 FBQ2496
Left 20 channels
1 20Hz
2 21Hz
3 22Hz
4 23Hz
5 24Hz
6 25Hz
7 26Hz
8 27Hz
9 28Hz
10 29Hz
11 30Hz
12 31Hz
13 32Hz
14 33Hz
15 34Hz
16 35Hz
17 36Hz
18 37Hz
19 38Hz
20 39Hz
Right 20 channels
1 40Hz
2 41Hz
3 42Hz
4 43Hz
5 44Hz
6 45Hz
7 46Hz
8 47Hz
9 48Hz
10 49Hz
11 50Hz
12 51Hz
13 52Hz
14 53Hz
15 54Hz
16 55Hz
17 56 Hz
18 57Hz
19 58Hz
20 59Hz
2 FBQ2496
Left 20 channels
1 60Hz
2 61Hz
3 62Hz
4 63Hz
5 64Hz
6 65Hz
7 66Hz
8 67Hz
9 68Hz
10 69Hz
11 70Hz
12 71Hz
13 72Hz
14 73Hz
15 74Hz
16 75Hz
17 76Hz
18 77Hz
19 78Hz
20 79Hz
Right 20 channels
1 80Hz
2 81Hz
3 82Hz
4 83Hz
5 84Hz
6 85Hz
7 86Hz
8 87Hz
9 88Hz
10 89Hz
11 90Hz
12 91Hz
13 92Hz
14 93Hz
15 94Hz
16 95Hz
17 96Hz
18 97Hz
19 98Hz
20 99Hz
70mm was regarded as the Rolls Royce of picture and sound in its day.
Old 10-12-08, 04:08 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Multiple BFQ2496 patched together?
I assume you mean FBQ2496?
And why would you want to do this? A parametric equalizers purpose is generally to tame peaks caused by the modal resonances in a room. Usually, a few carefully matched filters can tame any subwoofers response. There is little need or advantage to using 80 filters to obtain an ultra flat response that would only be valid at one finite spot in a room. A few inches away and it wouldn't be an ultra flat response any more.
Old 10-12-08, 04:15 PM   #3
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Hi Andy,
There are at least a few problems with this approach.
For one, the number of whole-number frequencies doubles with each octave. Notice that you only have twenty proposed filters between 20-40 Hz, but forty between 40-80 Hz. So to keep things linear, you'd need half-frequency steps below 40 Hz, and quarter-frequency steps above 80 Hz. The FBQ2496 can't do increments like that.
For another, it's impossible for an equalizer to have a filter set so tight that it only affects a single frequency. Every filter "bleeds" over to adjacent frequencies, and the more it is boosted or cut, the wider it "bleeds."
Also, it's generally considered undesirable to over-filter a sound system.
Fortunately, it isn't necessary to to achieve per-frequency linearity to get excellent sounding bass. In fact, a number of people who frequent this Forum found out the hard way that their bass sounded better when they cut back on the number of filters they were using, even if response didn't look quite as "pretty."
Suggested reading:
On Mminimal EQ and a Hard Knee House Curve
Old 10-12-08, 04:24 PM   #4
Alias: andy summers
Andysu's Avatar
Loc: United Kingdom
User: #20513
Since: May 2008
  Andysu is offline
brucek wrote: View Post
LOL I always get the letters mixed up always. Yes FBQ2496.
One spot in the room now that does seem limited oh well it’s just a thought and since these units sale cheaper than biscuits at Harrods, it’s worth a try to explore its potential, to see how far it can be taken.
Thanks anyway.
Old 10-12-08, 04:37 PM   #5
Alias: andy summers
Andysu's Avatar
Loc: United Kingdom
User: #20513
Since: May 2008
  Andysu is offline
Evening Wayne
I guess you, posted just about the last time I, did. Okay so it’s not valid way to do it okay what else can it be used foe besides doing two subs per channel etc, etc.
I remember reading about adjacent filters on poor EQ’s that crosstalk badly so is the BFQ2496 a poor-mans EQ I don’t think it is its performance is great, but I’d like to explore it further.
Old 10-12-08, 10:23 PM   #6
Alias: Wayne
Loc: Katy, Texas
User: #8
Feedback control in a PA system.
I remember reading about adjacent filters on poor EQ’s that crosstalk badly...
Whatever you saw was probably talking about graphic equalizers, where a slider (filter) boosted or cut also raises or lowers the gain of the frequency center of adjacent sliders (although in a lesser amount), even if they are not moved at all. This isn't a problem with parametric EQs, where a problem like that (in the unlikely event it would even occur) could literally be adjusted away with the bandwidth control.
bfq2496, multiple, patched, together?
