| BFD | Electronic Equalization Devices FBQ delay/sync with mains?Discuss FBQ delay/sync with mains? in the Equalization | Calibration forum; FBQ delay/sync with mains? Hi,
I just got my FBQ2496 this afternoon!
Question is, once I set it up, being that its taking the ... |
Views: 393 - Replies: 8
| FBQ delay/sync with mains? Hi, I just got my FBQ2496 this afternoon! Question is, once I set it up, being that its taking the analog signal from my Reciever/sub out, digitizing it, tweaking it, then re-analoging it, then sending it to my subs amp, then out to my subs; how can I adjust the delay in the rest of my system to accomodate the delay that will be introduced to the LFE after all this processing? System: Yamaha RX-Z1 (all speakers crossed over at 90hz) Paradigm studio reference (40's,cc570,adp590's) SVS cs25-31plus X2 / 1200watt samson 2ch amp FBQ2496 EQ for subs (everything below 90hz) Thanks for any suggestions you might have! | ||||
| | #2 | |||||
| Re: FBQ delay/sync with mains? Quote:
brucek | |||||
| | #3 | ||||
| Re: FBQ delay/sync with mains? I'm not sure how long the delay is, but I believe the standard solution is to just set the distance to the subwoofer to a bit farther than it actually is. This way, the receiver has to send the signal to the FBQ earlier, so that the sounds all reach the LP at the same time. I would bet someone will be along shortly to tell us how long the delay is, and how many inches/feet that equates to in the speaker settings edit: And there's brucek, beating me to the punch. Last edited by tenzip; 10-30-08 at 06:38 PM.. Reason: Bruce beat me. | ||||
| | #4 | |||||
Any other ideas??? | |||||
| | #5 | ||||
| Re: FBQ delay/sync with mains? If your receiver has no sub distance setting, what makes you think it is correct now? Use REW to measure the response through the crossover region and try changing the sub's phase, if your sub has phase adjustment or phase inversion, to get the best response through that region. If you haven't already been through the process of measuring response to see where your sub is best placed may want to do that first. | ||||
| | #6 | ||||
| Re: FBQ delay/sync with mains? I believe the YPAO will set the distances/delays correctly if you just run it. I took a quick look at the manual, and didn't see any way to manually set them. | ||||
| | #7 | |||||
For what its worth, here is a link to the manual: http://www.mbmania.com/bin/RX_Z1_owners_manual.pdf It really doesn't seem that long ago that I bought this reciever! And cost still pains me! LOL! | |||||
| | #8 | ||||
| Re: FBQ delay/sync with mains? Wow, that's weird. I looked up that model number on the Yammy site, and came up with a different receiver, one that had YPAO. | ||||
| | #9 | |||||
http://www.yamaha.com/yec/products/p...ETYP=ATTRIBUTE I don't recall there ever having been YPAO on any of the Z1's. The Z9 replaced the Z1 and that one had YPAO if I remember correctly. | |||||
| Bookmarks |
| Tags |
| delay/sync, mains? |
| Thread Tools | |
