| BFD | Electronic Equalization Devices Consensus on BFD+Audyssey for house curve?Discuss Consensus on BFD+Audyssey for house curve? in the Equalization | Calibration forum; Consensus on BFD+Audyssey for house curve? Noob here, but I've used REW to determine Audyssey has given me a fairly flat response. I've been reading the ... |
Views: 684 - Replies: 11
| Consensus on BFD+Audyssey for house curve? Noob here, but I've used REW to determine Audyssey has given me a fairly flat response. I've been reading the guides on hard knee house curves and would really like to give it a try. Before I pull the trigger on the BFD 1124P I was hoping to get some input. Seems the consensus is to use the BFD to smooth out peaks before running Audyssey. This would leave me without being able to set a house curve b/c Audyssey is going to flatten everything out. I'm not too concerned about peaks with the sub anyways, Audyssey does a very good job itself. So what are the downfalls if I run the BFD after Audyssey EQ's everything? I've read a few people felt it would negate the Audyssey results b/c the BFD has fewer filters. Seems like it would be ok b/c if I understand the hard knee house curve you are basically just setting a deep wide filter for one frequency anyways right? I did find a thread at AVS that touches on the issue, reply #16 is of particular interest. http://www.avsforum.com/avs-vb/showthread.php?t=885535 Quote from reply #16 " I have a house curve from 75db to 80db, what I did was run the 1124 and cut everything down to about 74db. I then ran Audyssey with the eq on. After everything was set, I tooks the cuts out and set my house curve. I believe if you set the house curve before you run Audyssey it may try to cut your curve down to 75db." | ||||
| | #2 | |||||||
| Re: Consensus on BFD+Audyssey for house curve? Quote:
brucek | |||||||
| | #3 | ||||
| Re: Consensus on BFD+Audyssey for house curve? Wow ok well apparently I am way off. Thanks for straightening me out here. As long as I can use it to set a house curve after the auto setup w/ MultEQ XT, that would be AWESOME! I'm rereading the guides and I'm still a little fuzzy, are the filters applied only to the subwoofer? Or are they applied to the main speakers also? If it's just the sub I don't understand how the mains are supposed to be intergrated into the curve? | ||||
| | #4 | ||||||
brucek | ||||||
| | #5 | ||||
| Re: Consensus on BFD+Audyssey for house curve? What implementation of Audyssey do you have? If you have DynamicEQ that will sort the house curve for you. | ||||
| | #6 | |||||
1. Run Auto Setup w/ Audyssey to establish relatively flat response for sub and mains 2. Use AVIA disc to adjust all speakers to same db level (Audyssey tends to set my rears a little high and sub a little low for my taste) 3. Run REW to establish freq curve for sub/mains 4. Adjust filters in BFD to create house curve for SUB Am I missing anything? As for the Audyssey version, I have a Denon 2809 w/ MultEQ XT and it does have Dynamic EQ. However as I understand it this does not set a house curve. Dynamic EQ adjusts to maintain the same perceived response at lower volumes. For example it increases surround presence and bass as the volume is lowered to maintain the same EQ curve. The curve it is trying to maintain is not a house curve though. So my goal is too create a house curve that Dynamic EQ will try to maintain as it adjusts. Please correct me if this is wrong. | |||||
| | #7 | ||||
| Re: Consensus on BFD+Audyssey for house curve? The house curve is there to compensate, just like DynamicEQ is. If you're properly calibrated and running at reference you shouldn't need a house curve. | ||||
| | #8 | ||||||
brucek | ||||||
| | #9 | |||||
With a house curve, lower and higher freq are perceived at the same level. For example at a 75db listening level, the 30 hz is actually at 75db, and 100 hz is actually at 70hz, but both are perceived at 75db. Onto Dynamic EQ. Dynamic EQ isn't active whatsoever at reference level, it only kicks in as you lower the volume. As you lower volume it increases the lower frequencies so that they still appear to maintain the same 1:1 ratio with the higher frequencies. Apparently this is to compensate for the human ear's diminished perception of lower frequencies as volume decreases (this seems to be a completely seperate issue from how a particular room causes certain frequencies to be perceived as louder than others, aka house curve.) So with Dynamic EQ at a 75db listening level, since Audyssey flattens everything out, 30hz is actually 75db and 100hz is actually 75 db (not a house curve). As you turn down the volume lower than reference, lets say 65 db, the 30hz and 100hz frequencies are still heard with the same mix (whereas without Dyn EQ, 30 hz might be perceived as lower.) So since both are heard at the same level (or at least what Audyssey thinks is the same level), it still leaves the 100hz frequency to be perceived louder (according to the house curve theory.) It attempts to return what is perceived back to the original flat curve it started with. So although it helps to at least get back to flat, it doesn't take the next step to compensate for the house curve. And that's what makes me think I still need to adjust for a house curve. | |||||
| | #11 | ||||
| Re: Consensus on BFD+Audyssey for house curve? DynEQ does make it flat (perceived), which is the point of a house curve as well. If you are calibrated flat and always listen at reference, most peope would have more than enough bass. It's once you turn down the volume you feel the need for a house curve, and that's exactly what DynamicEQ does for you. If flat with DynEQ isn't enough bass for you, THEN get a house curve. Most reports I've read after getting DynEq is that people think it's a bit on the bass-heavy side. Add a +6dB house curve and you're probably hearing your subs way too loud. | ||||
| | #12 | |||||
| Bookmarks |
| Tags |
| bfd+audyssey, consensus, curve?, house |
| Thread Tools | |
