Exodus Audio - Home of the infamous drivers using the XBL^2 motor technology!
BFD Questions MIDI, PHASE
Discuss BFD Questions MIDI, PHASE in the Equalization | Calibration forum; BFD Questions MIDI, PHASE 1) I was reading BruceK's BFD review it noted that the BFD generates a phase shift in the signal. How ...
Old 12-03-08, 08:18 PM   #1
Alias: Anthony
Loc: Michigan
User: #23938
Since: Aug 2008
  MichiganMan is offline
1) I was reading BruceK's BFD review it noted that the BFD generates a phase shift in the signal. How big of an issue is it? Would it ever be a problem?
2) Without the MIDI cable will REW automatically generate the filter settings like those pictured in the help guide?
http://www.hometheatershack.com/foru....html#post1063
Old 12-04-08, 07:01 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: BFD Questions MIDI, PHASE
Phase shift isn't a concern over the bandwidth where a sub acts alone. You can't hear a phase shift. The concern is when another speaker is also outputting a signal that can then result in cancellation. This bandwidth of concern is through the crossover region. That's why a sub has a phase control to compensate for cancellations or additions over the crossover area.
Yes, the midi cable is only used to download filters from REW into the BFD. They are just as easily entered by hand. I have never owned or used the midi cable. I would have my filters entered before you had the cable hooked up.
midi, phase, questions
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314
