| BFD | Electronic Equalization Devices Question on building an RCA to 1/4 inch cable for the BFD?Discuss Question on building an RCA to 1/4 inch cable for the BFD? in the Equalization | Calibration forum; Question on building an RCA to 1/4 inch cable for the BFD? edit... just realized the title is misleading, actually should be processor-->BFD-->sub amp
So I've just picked up an 1124P and ... |
Views: 1507 - Replies: 2
| Question on building an RCA to 1/4 inch cable for the BFD? edit... just realized the title is misleading, actually should be processor-->BFD-->sub amp So I've just picked up an 1124P and I'm off to get a couple of 1/4" mono connectors to make up some cables. I've made sub cables before, RCA-RCA, always with the shield attached to return at one end only. I've read that it's supposed to make a difference as to which end the shield-attached end is placed at (supposed to be at source end, IIRC). Honestly, I can't hear a difference, and the logic behind the shield attachment being at one end or the other escapes me. Question: with two cables in the making, sub-out RCA-->1/4" BFD, BFD 1/4"-->RCA sub amp in, is there a recommended shield attachment configuration? Any ideas on this? Obviously, not reversible like a RCA-RCA cable, so would like to get it right if it makes a difference. thanks... GB | ||||
| | #3 | |||||
| Re: Question on building an RCA to 1/4 inch cable for the BFD? Quote:
Regards, Wayne | |||||
