Which Sub Location Do You Like?
Discuss Which Sub Location Do You Like? in the Equalization | Calibration forum; Which Sub Location Do You Like? I have a DSP1124P under my tree with my name on it. But before I play with it I wanted ...
Views: 786 - Replies: 19
Old 12-22-08, 07:50 PM   #1
Alias: Anthony
Loc: Michigan
User: #23938
Since: Aug 2008
  MichiganMan is offline
But before I play with it I wanted the best non-equalized position for my sub as a starting point. For these two graphs I'm running a single notch filter at 25hz -10db to tame a hump that would otherwise be present. The X-Over is set to 80hz at the processor
What position do you prefer? A or B. I know it can be subjective, I'm just curious what someone else might think.
Old 12-22-08, 08:50 PM   #2
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: Which Sub Position Do You Like?
For me ...B position (that dip on A is larger than the dip on B).
Old 12-22-08, 09:01 PM   #3
Alias: Steven
thewire's Avatar
Loc: Midwest
User: #9828
Since: Jun 2007
  thewire is offline
How did you know it's under the tree did you put it there? Just curious. B looks best and the dip isn't in the 40Hz area so looks good to me.
Old 12-22-08, 10:17 PM   #4
Gold Supporter
Alias: Jean-Pierre
imbeaujp's Avatar
Loc: Beaumont, Quebec, CANADA
User: #12596
Since: Oct 2007
  imbeaujp is offline
Hello, try changing the phase on your sub to see if you have some improvement. If you do not have a phase control, you can change de delay or distance on your receiver. Just 1 foot increment could have an impact.
what will be your crossover frequency ? Are you going to use a Housecurve ? Have you check it with your mains ?
Many questions before using your EQ !
Old 12-23-08, 10:20 AM   #5
Alias: brucek
User: #6
  brucek is online now
Yeah, choose A and get rid of the dip at 66Hz with the phase control.........
Old 12-23-08, 12:01 PM   #6
Alias: Anthony
Loc: Michigan
User: #23938
Since: Aug 2008
thewire wrote: View Post
Yes My wife and I pick out most of our presents too each other that way everyone is happy and no returns.
I never thought to use the phase control I'll adjust it at the processor that way I can adjust in discrete increments. Now that will have an impact at the cross over point right? Is there anything to be on the watch for?
I'm crossing over all speakers at 80hz.
I find my self boosting the sub especially with music. A true flat response seems dull. Eventually I'll use a house curve when I get more proficient at this stuff.
I do have sweeps with the mains included. But I thought the general rule of thumb was to position and equalize the sub first then add in the mains and perform some final tweaks.
Old 12-23-08, 12:57 PM   #7
Alias: brucek
User: #6
Use the subs phase control first. If that's not successful, then use the sub distance control. (remember the phase control only has an effect once the mains are added)
Correct, but you've done all you can with the sub and you have a dip right at the crossover. Add the mains and use the phase control to remove the problem.
Old 12-23-08, 02:21 PM   #8
Alias: Anthony
Loc: Michigan
User: #23938
Since: Aug 2008
brucek wrote: View Post
Got it!
Is there reason to adjust the phase at the sub rather than through the processor (pre-amp)?
Old 12-23-08, 03:16 PM   #9
Alias: brucek
User: #6
The result is generally the same. Sometimes it may be easier to adjust the subs phase dial.
I find it easiest to adjust to adjust the subs phase dial in real time by using the RTA feature of REW while watching the computer screen. I can tell you how to set that up if you have trouble...
Old 12-23-08, 06:31 PM   #10
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
I vote B. It looks like the readings were taken with the mains off, so there's not much chance that phase or distance controls will take out the 66 Hz depression the A graph has.
Old 12-23-08, 08:51 PM   #11
Alias: Anthony
Loc: Michigan
User: #23938
Since: Aug 2008
Is this the expected level of change from a phase adjust of the sub? Pictured is the sub with mains and no filtering.
Old 12-23-08, 10:16 PM   #12
Alias: Wayne
Loc: Katy, Texas
User: #8
What's the crossover frequency?
Old 12-23-08, 11:25 PM   #13
Alias: Anthony
Loc: Michigan
User: #23938
Since: Aug 2008
Wayne,
The crossover is set to 80hz at the processor. The sub crossover is set to max, 150hz I believe. I'm assuming the processor crossover will assert control.
Not to change the subject, but why is 80hz the THX recomended/setting for the crossover point?
Would it not make sense to increase the crossover point so I can benefit from EQ'ing over a larger frequency range with the DSP1124p?
Anthony
Old 12-24-08, 06:44 AM   #14
Alias: brucek
User: #6
Not to change the subject, but why is 80Hz the THX recomended/setting for the crossover point?
Over 80Hz, the subwoofer become localizable - something you don't want.
A phase control can have anywhere from no effect to a very large effect, and over a fairly wide range.
The phase control is certainly having a effect between 50-60Hz in your graph.
Old 12-24-08, 08:31 AM   #15
Gold Supporter
Alias: Jean-Pierre
imbeaujp's Avatar
User: #12596
Since: Oct 2007
  imbeaujp is offline
I think you have a better result with 20 degree phase alignement in the 40-60 hz range. It is a nice boost without using any EQ !
Could you post the graph (20 degree) alone just to check it again ?
It is not too bad at all, in my system the crossover frequency is set to 60hz. My mains have large woofers, 12 inches, so I prefer to let them go in that area.
Old 12-24-08, 12:51 PM   #16
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
MichiganMan wrote: View Post
What speakers are you using??? ...Are you using them as small??? ...Did you try different crossover frequencies???
Old 12-24-08, 08:36 PM   #17
Alias: Anthony
Loc: Michigan
User: #23938
Since: Aug 2008
The speakers are Paradigm Studio 100's Servo15 sub. The speakers are set to large. I haven't tried any different crossover frequency yet.
Old 12-26-08, 12:56 PM   #18
Alias: Wayne
Loc: Katy, Texas
User: #8
Re: Which Sub Location Do You Like?
Rescale your graphs for 45-105 dB and your response won't look so scary...
Old 01-01-09, 09:15 PM   #19
Alias: Anthony
Loc: Michigan
User: #23938
Since: Aug 2008
Wayne,
I did that just so I could see the difference between the two graphs.
At the default scale I could hardly notice a difference.
Old 01-01-09, 09:50 PM   #20
Alias: Wayne
Loc: Katy, Texas
User: #8
No need to do that - REW has a function that will shift a trace up or down for easier comparison to another traces.
like?, position
