| BFD | Electronic Equalization Devices BFD Questions! House Curve Questions! Discuss BFD Questions! House Curve Questions! in the Equalization | Calibration forum; BFD Questions! House Curve Questions! Howdy! I have been reading these threads like mad and have found a ton of great information. I have a ... |
Views: 1138 - Replies: 5
| BFD Questions! House Curve Questions! Howdy! I have been reading these threads like mad and have found a ton of great information. I have a pretty good understanding of how this all works, but I do have some questions- hope you can help! 1. Determining House Curve: I understand how you find the low end by listening at 32 and 80 hz and then adjusting until they sound the same volume, but what about the high end? Same process? 2. Once you have calibrated for your House Curve, how do you match the sub to the fronts so the house curve is consistent into the highs? Could you adjust the volume on the sub and verify it all adds up by taking readings? Or do you have to adjust the level of the sub at the receiver? I hope these make sense! Ryan | ||||
| | #2 | ||||||
| Re: BFD Questions! House Curve Questions! Quote:
Without REW, you will simply adjust your subwoofer amp after equalization by ear. Whatever sounds good to you. There is no right or wrong level - just guidelines to match them so they blend together at the same level at the crossover. Quote:
brucek | ||||||
| | #3 | ||||
| Re: BFD Questions! House Curve Questions! Thanks for the response, I appreciate it! I am planning on using Room EQ and the BFD for the sub. I have a Yamaha 5790 with the YPAO feature which will adjust for the mains/surrounds. YPAO has different settings which may be interesting. You can allow it to self-calibrate as a Parametric EQ or you can adjust each channel via 7-Band Graphic EQ. Would you recommend not using the YPAO at all? I will take measurements of the room WITHOUT treatment and see what happens. I will then add my first layer of treatment (1" Linacoustic RC on side walls up to ear level and 1" on front wall floor to ceiling) and take another measurement. THEN I will add bass traps in the four corners and measure again! Should be fun. This is a few weeks out and I have not yet purchased the BFD, but I think it is inevitable that I will want it- what do you think? | ||||
| | #4 | ||||||
There have been members here who have used processor EQ (such as YPAO) and run it first, then added BFD equalization. This would seem like a good way to go. Quote:
brucek | ||||||
| | #5 | |||||||
Regards, Wayne | |||||||
| | #6 | ||||
| Re: BFD Questions! House Curve Questions! Thanks, Wayne- Good information. I have an external sound card on the way and have already downloaded REW. I am just about ready to sheetrock the HT room- should be able to take some measurements in the next few weeks! Then I can decide whether or not the BFD will be a necessity! Ryan | ||||
