| BFD | Electronic Equalization Devices DSP1100 Level setting, Bridge of Khazad-dumDiscuss DSP1100 Level setting, Bridge of Khazad-dum in the Equalization | Calibration forum; DSP1100 Level setting, Bridge of Khazad-dum Quick question. I want to verify that I have chosen something with enough high volume LFE. I am using this ... |
Views: 334 - Replies: 4
| DSP1100 Level setting, Bridge of Khazad-dum Quick question. I want to verify that I have chosen something with enough high volume LFE. I am using this scene and am getting the orange -3db light flickering on the highest point, where the Balrog steps onto the bridge. Does that sound good, or is there something else I should use? BruceK if you read this. Your instructions in the BFD guide are great! I have gotten this far without much effort. I must say that the BFD interface seems really intuitive. I was able to set a filter (mostly) without reading the instructions at all. Now, off to set some more filters and test this thing out. ![]() | ||||
| | #2 | |||||
| Re: DSP1100 Level setting, Bridge of Khazad-dum Quote:
Regards, Wayne | |||||
| | #3 | ||||
| Re: DSP1100 Level setting, Bridge of Khazad-dum Doh! What movie, I didn't mention the title, just the scene. ![]() Lord of the Rings, Fellowship of the Ring, scene 36, Bridge of Khazad-dum. One of the guides suggested adjusting the level on the receiver until the loudest scenes just light the orange warning light. Hopefully someone else chimes in. I'm pretty sure its a reasonably well known movie. ![]() | ||||
| | #4 | ||||
| Re: DSP1100 Level setting, Bridge of Khazad-dum That movie should be bass-heavy enough for setting the levels. ![]() Regards, Wayne | ||||
| | #5 | ||||
| Re: DSP1100 Level setting, Bridge of Khazad-dum Thanks Wayne. I decided to dial it back just a little so I don't get into the orange. I put the first filter in (hopefully correctly): a 14db cut at 56.2Hz. Playing the speaker leveling test tones, there is a 3-4db difference between bypass and when the filter is engaged. | ||||
