BFD | Electronic Equalization DevicesDiscuss FBQ 2496 Range?? in the Equalization | Calibration forum; FBQ 2496 Range?? Just a simple question.. At what FR can the FBQ operate?? I have one already running my SW's which will ... |
Views: 466 - Replies: 10
| FBQ 2496 Range?? Just a simple question.. At what FR can the FBQ operate?? I have one already running my SW's which will probably run between 2 0-80hz. But can I add a second one to do the range from about 80-600hz?? I know a deq could do it,but I suppose I'm just trying to keep the mids out of ant extra AD/DA coversion. Cheers the Joz Peace love and Mungbeans | ||||
| | #3 | ||||
| Re: FBQ 2496 Range?? I am not sure if the FBQ is the same, but the DCXs range can be extended by using a low Q filter at the low/high end of its range. Such use extends the function of such units, but is not as accurate. If used in such a way proper loop back measurement would be recommended before real world implementation. Andrew | ||||
| | #4 | |||||
| Re: FBQ 2496 Range?? Sure, as long as you're using an outboard amp for the mids. The only way to connect an equalizer is between the pre-amp and amp. Quote:
Regards, Wayne | |||||
| | #5 | |||||||
| Re: FBQ 2496 Range?? Quote:
Also so I don't start another thread.. Is it possible to get an extension lead for midi connection?? The one on the edirol is very short. Cheers the Joz Peace love and Mungbeans | |||||||
| | #6 | ||||
| Re: FBQ 2496 Range?? Excellent thanks,just makes me wonder why people use it just for bass?? Cheers the Joz Peace love and Mungbeans | ||||
| | #7 | ||||
| Re: FBQ 2496 Range?? I use a pair of 5Mtr (in/out) leads with my USB/Midi adapter with no know issues. Cheers Minty | ||||
| | #8 | |||||
| | #9 | |||||
For most people with a late-model receiver, the on-board equalization is adequate or their needs, especially with the more upscale receivers. Regards, Wayne | |||||
| | #10 | ||||||
ofcourse thanks. Cheers the Joz Peace love and Mungbeans | ||||||
