Velodyne SMS-1 or Antimode 8033
Discuss Velodyne SMS-1 or Antimode 8033 in the Equalization | Calibration forum; Velodyne SMS-1 or Antimode 8033 Hi Guys! I am looking at sub EQ for my room which has 2 modal peaks(8db @ 28hz & 12db ...
Views: 836 - Replies: 8
Old 02-06-09, 10:58 AM   #1
Alias: vinod valiveti
Loc: camarillo, CA
User: #26426
Since: Sep 2008
  vinodk is offline
Hi Guys!
I am looking at sub EQ for my room which has 2 modal peaks(8db @ 28hz & 12db @ 50hz with corresponding dip at 40hz). I am contemplating between SMS-1 & 8033 now that they are priced almost the same. BFD/REW are too daunting for me to use. I am seeking an opinion from all you experts as to which is better: SMS-1 in manual mode or 8033. I do realize that SMS-1 in auto mode is not as good.
Thanks.
Old 02-06-09, 01:01 PM   #2
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
  Kal Rubinson is offline
Re: Velodyne SMS-1 or Antimode 8033
vinodk wrote: View Post
Hi Guys!
Thanks.
I would go with the 8033 since the SMS-1 does not show/do anything about decay times.
Kal
Old 02-06-09, 04:44 PM   #3
Alias: Artie
Loc: I ain't tellin ya!
User: #1700
  spyboy is offline
Kal Rubinson wrote: View Post
Kal
Thanks for your opinion. Have you directly compared the two EQ's in question?
If one was using sealed subwoofers would decay time make as much of a difference?
Old 02-06-09, 07:20 PM   #4
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
spyboy wrote: View Post
Not A/B but with the same equipment in the same room.
Irrelevant. The decay is a function of the room modes. (Both of my subs are sealed.)
Kal
Old 02-06-09, 10:25 PM   #5
Loc: camarillo, CA
User: #26426
Since: Sep 2008
  vinodk is offline
Thanks Kal. What exactly does decay time mean & how impotant is it to correct it? BTW I am using Martin Logan Descent i located just inside of right speaker.
Old 02-07-09, 12:19 PM   #6
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
Due to the room's dimensions and surfaces (as well as listener and speaker placement), it will superimpose resonances/modes/nulls at defined frequencies which will continue to 'sound' long after the original signal ceased (or should have). These superimposed sounds will color the reproduction and they should be eliminated or curtailed for accurate sound. There are ways to do this. Some will simply reduce the output at those frequencies and that, imho, is a bandaid and not very effective. Others will implement a digital filter with matching time signature to them and shorten/minimize the extended decay. While the latter can best be done with proper room design and treatment, some electronic EQs can also do this.
Take a look at RoomEQ Wizard for a program to measure/visualize this.
Kal
Old 02-07-09, 12:35 PM   #7
Loc: camarillo, CA
User: #26426
Since: Sep 2008
  vinodk is offline
Thanks Kal. That was an excellent yet simplistic way to explain it. I guess I will be ordering 8033.
Old 02-07-09, 01:12 PM   #8
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
Simple but, I hope, not simplistic.
Kal
Old 11-18-09, 11:15 PM   #9
Loc: camarillo, CA
User: #26426
Since: Sep 2008
  vinodk is offline
Hi Guys!
Have been using 8033 for past few months. I am planning to place SMS-1 in the loop along with 8033 to visualize & have better control over 8033. Will be interesting to see what happens. I am hoping it will be best of both worlds with better EQ/time alignment of 8033 coupled with fine tuning/presets with SMS-1.
8033, antimode, sms-1, velodyne
