| BFD | Electronic Equalization Devices 10 Filters for BFD using REW??Discuss 10 Filters for BFD using REW?? in the Equalization | Calibration forum; 10 Filters for BFD using REW?? I got BFD last week and got my first measurements yesterday with M-Audio USB Pre. While I was reading up ... |
Views: 451 - Replies: 4
| 10 Filters for BFD using REW?? I got BFD last week and got my first measurements yesterday with M-Audio USB Pre. While I was reading up on REW/BFD combination, I read comments that you should not need more than 4-5 filters to have relatively flat response curve. However, REW recommended 10 filters to me. Most of the filters were in the range of 20 to 32 Htz (Sorry, I do not have the details at this time, will post the filter details later). I thought only couple of filters should have done the job to negate 10-15db gain I was seeing between 20-32 Htz. Is having too many filters a bad thing because then BFD will need more time to process thereby adding some lag? | ||||
| | #2 | |||||
| Re: 10 Filters for BFD using REW?? Quote:
brucek | |||||
| | #4 | |||||
Regards, Wayne | |||||
| | #5 | ||||
| Re: 10 Filters for BFD using REW?? Hi Wayne, Yes, the room gain was close to 10-14 DB between 20 to 35Htz. I'm having trouble posting an image. I did not run the set target routine before running the EQ routine. I'll try that. Thanks for your input. | ||||
