Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Equalization | Calibration > BFD | Electronic Equalization Devices
  Discuss MIDI or manual entry with 1124P? in the Equalization | Calibration forum; MIDI or manual entry with 1124P? Hello all, Received my 1124P today and had a quick question about the MIDI interface. Is this highly recommended, or ...
Views: 710 - Replies: 11
Old 02-16-09, 05:14 PM   #1
Alias: Joe
Loc: Pennsylvania
User: #33460
Since: Feb 2009
  jschaefer7406 is offline
Hello all,
Received my 1124P today and had a quick question about the MIDI interface. Is this highly recommended, or should I just skip buying the MIDI cable and enter the filter settings manually? If it is recommended, do I have to use the Edirol cable, or will the cheap $14.xx interface cables on Ebay suffice?
Thanks in advance,
Joe
Old 02-16-09, 05:22 PM   #2
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
Re: MIDI or manual entry with 1124P?
When I had the 1124, I vastly preferred to use the MIDI connection. It's not hard to enter it by hand, but if you're doing multiple measurements and experiments, it's much faster and less prone to error.
If you're going to just do it once and leave it, you're probably OK to do it by hand. If you're a tweaker and you're going to try this and then try that and then try something else, you'll find that it's more efficient to use the MIDI connection.
I don't know about the specifics of the cables.
-- Otto
Old 02-16-09, 05:32 PM   #3
Alias: brucek
User: #6
  brucek is offline
I bet I can enter the filters by hand before you get the cable hooked up......
Old 02-16-09, 06:09 PM   #4
Alias: hjones4841
hjones4841's Avatar
Loc: Central AL
User: #32516
Since: Jan 2009
  hjones4841 is online now
The problem I have with manual entry is remembering what to add/subtract to get the frequency I want. For that reason, I hook up the MIDI cable.
Old 02-16-09, 07:09 PM   #5
Alias: brucek
User: #6
  brucek is offline
Huh? REW tells you what numbers to enter in Freq and Fine.
Old 02-16-09, 08:22 PM   #6
Alias: Joe
Loc: Pennsylvania
User: #33460
Since: Feb 2009
Hello again,
I did decide to order the MIDI cable from Amazon. Only $10 or so shipped, figured what the . Manual entry would have worked (I would have figure it out eventually), but for that price, why mess around with it?
Joe
Old 02-17-09, 04:18 AM   #7
Alias: hjones4841
hjones4841's Avatar
Loc: Central AL
User: #32516
Since: Jan 2009
brucek wrote: View Post
OK, guess I missed that. I was using the chart in the BFD manual.
Old 02-17-09, 04:19 AM   #8
Alias: hjones4841
hjones4841's Avatar
Loc: Central AL
User: #32516
Since: Jan 2009
jschaefer7406 wrote: View Post
Hello again,
Joe
Remember to go thru the steps to enable MIDI on the BFD itself.
Old 02-19-09, 11:24 AM   #9
Alias: jdeanmc
Loc: decatur,al
User: #24837
Since: Aug 2008
  jdeanmc is offline
I agree.Ive changed my filters so many times recently,that i can enter filters on this thing faster than i can type on this keyboardit is very easy.
Dean
Old 06-07-09, 10:48 PM   #10
Alias: phil
User: #34256
Since: Feb 2009
  VERTIGGO is offline
I'm also beginning to subscribe to the manual filter method.
In fact, I've found the REW measurements don't match my ears' perception. For example, I've found that running a sine wave generator in REW and sliding it across with the mouse, listening for peaks, and dialing in filters while listening gives me a much flatter response. It must be my ears, because the sweeps may show dips and peaks but I think the response my ears pick up is more important.
J. Edward McGarvey
MY DIY SUB
Onkyo TX-SR806, 3 Yamaha NS-777, 2 NS-333, Panasonic PT-AE2000U
1124p?, entry, manual, midi
Bookmark and Share
Dish Network
