Software version in DSP1124p
Discuss Software version in DSP1124p in the Equalization | Calibration forum; Software version in DSP1124p Hi, just received a new DSP1124p date code 0811. Will this work with edirol midi adaptor as is or will ...
Views: 350 - Replies: 5
Old 02-18-09, 06:11 PM   #1
Alias: Ben
Loc: Rockhampton, QLD.
User: #31697
Since: Jan 2009
  gtvben is offline
Hi, just received a new DSP1124p date code 0811. Will this work with edirol midi adaptor as is or will I have to update the software. I was hoping the unit would show me the software version on startup?
It would be nice to know before I go to the trouble of purchasing a midi adaptor if I chose to go this way. Not sure if this v1.3 software thing was solved many moons ago???
Old 02-18-09, 06:15 PM   #2
Alias: hjones4841
hjones4841's Avatar
Loc: Central AL
User: #32516
Since: Jan 2009
  hjones4841 is offline
Re: Software version in DSP1124p
I got mine from Amazon two weeks ago. It has 1.4 firmware and MIDI works fine.
Old 02-18-09, 06:23 PM   #3
Alias: Ben
User: #31697
Since: Jan 2009
  gtvben is offline
Thanks, sounds like I won't have a problem. Looks like REW using MIDI to set filters is the way to go, do you agree?
Old 02-18-09, 06:25 PM   #4
Alias: Ben
User: #31697
Since: Jan 2009
  gtvben is offline
Also, how do you find what version software/firmware you have?
Old 02-18-09, 06:59 PM   #5
Alias: hjones4841
hjones4841's Avatar
Loc: Central AL
User: #32516
Since: Jan 2009
Instructions for checking firmware were posted in another thread discussing the MIDI problem with 1.3: Power up the unit while holding down the Filter Select button and read the Version # displayed
Old 02-18-09, 08:36 PM   #6
Alias: Ben
User: #31697
Since: Jan 2009
  gtvben is offline
thankyou hjones.
dsp1124p, software, version
