| BFD | Electronic Equalization Devices Cable grounding and my Ep2500Discuss Cable grounding and my Ep2500 in the Equalization | Calibration forum; Cable grounding and my Ep2500 Hi guys, I need some advice.
I get a huge ground loop hum using my ep2500 through my sub rendering ... |
Views: 483 - Replies: 7
| Cable grounding and my Ep2500 Hi guys, I need some advice. I get a huge ground loop hum using my ep2500 through my sub rendering the system useless. When I disconnect the coax from the back of the cable box, ground loop hum goes away and I can use my system. I can add a cheater plug to the ep2500, and it works perfectly while the coax IS Connected to the cable box. Remove the cheater plug, no go. Connect the coax, no go. The ep2500 is on a different 20amp outlet as the processor, and cable box, but on the same circuit. I went outside to check grounding. The cable company has their phone, cable, and internet (I get all 3 services from my cable company) grounded with straps to the conduit of the meter mast. Of course the meter/house is grounded with a long copper solid pipe into the ground. Is having the phone, cable, and internet grounded to the mast a proper ground? Can I possibly be getting ground loop hum caused by this bad or incorrect grounding method? My cable company wont even come check out their grounding, as they don't ground anything, my electrician grounded everything. I did not hire a electrician to ground their equipment on the outside of my house. I watched them add these ground straps myself. Any input would be very helpful as I will have to pay an electrician to come check their work and all grounds. Thanks ahead of time... Andy | ||||
| | #2 | ||||
| Re: Cable grounding and my Ep2500 It should be connected directly to the ground rod or the ground wire going to the rod. It may be getting a good connection, but I would measure it. Make sure that the circuits are on the same side, preferably adjacent in the meter panel. Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
| | #4 | ||||
| Re: Cable grounding and my Ep2500 Use an DMM and measure ohms. Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
| | #6 | ||||
| Re: Cable grounding and my Ep2500 I'm assuming you check at the coax behind my cable box? Can you explain further please. Thanks again for all the input so far. I want to be armed with some info. before i go to the owner of the company. I'm mad at them for not even being cool enuff to look at it when i pay $180.00/mth for their services.... Thanks again.. EDIT> I'm picking up what your putting down! Last edited by Blktre; 02-24-09 at 08:49 PM.. | ||||
| | #7 | ||||
| Re: Cable grounding and my Ep2500 Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
