Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Equalization | Calibration > BFD | Electronic Equalization Devices
  Discuss BFD Setup Help in the Equalization | Calibration forum; BFD Setup Help I measured with REW in 6 positions (same used for Audyssey setup) and the Averaged and REW provided following Filters. ...
Views: 453 - Replies: 3
Old 02-27-09, 03:22 PM   #1
Alias: Mark
User: #33866
Since: Feb 2009
  BritInVA is offline
BFD Setup Help
I started manually setting filters to Preset 10 (as BFD will be switched on/off by a Power Conditioner)
On FILTER 1 Iused
FINE = -2
BANDWIDTH = 4
GAIN = -3
Then pressed STORE STORE
When I go in FILTER 2 and press FREQUENCY the display shows .50 but am unable to change it with the jog dial.
What am I doing wrong?
Cheers,
Mark
Old 02-27-09, 04:30 PM   #2
Alias: Mark
User: #33866
Since: Feb 2009
  BritInVA is offline
Re: BFD Setup Help
I have been able to set filters on preset 5. Not sure why preset 10 is not working. Only thing I see different is on present 10 all the Red LED's are flashing (except the LED for filter 1 whigh was programed).
With Preset 5 only the filters that are programmed are lit.
Also how do you erase a filter?
Cheers,
Mark
Old 02-27-09, 06:31 PM   #3
Bronze Supporter
Alias: George
Loc: Lafayette, LA
User: #32511
Since: Jan 2009
  joorge is offline
Re: BFD Setup Help
Set the gain to zero and save for each filter.
Old 02-27-09, 06:35 PM   #4
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
  Hakka is offline
Re: BFD Setup Help
Try changing the filter mode to PA, it sounds like its on SS at the moment.
Hakka.
setup
Bookmark and Share
Dish Network
