| BFD | Electronic Equalization Devices DCX2496 does this work like the FBQ2496 to eq?Discuss DCX2496 does this work like the FBQ2496 to eq? in the Equalization | Calibration forum; DCX2496 does this work like the FBQ2496 to eq? I have done a bunch of reading on these units, and really like the looks of the DCX2496 for its ... |
Views: 1223 - Replies: 28
| DCX2496 does this work like the FBQ2496 to eq? I have done a bunch of reading on these units, and really like the looks of the DCX2496 for its speaker management abilities. But I can't find much info on the parametric and band pass eq abilities. Does this have 1/60 octave para eq like the BFD and FBQ? My goal is to be able to take a two channel input, and split it into three (or four) outputs, that way I can high pass and eq my mains, and low pass and eq the sub separately without one effecting the other. Nice features on the DCX but for the additional money, I could buy an FBQ and a BFD. Hmmmmm... Thanks! | ||||
| | #2 | |||||
| Re: DCX2496 does this work like the FBQ2496 to eq? Quote:
brucek | |||||
| | #3 | ||||
| Re: DCX2496 does this work like the FBQ2496 to eq? I saw that in the specs...a Q of 0.1 - 10.0, found a formula for that and if I calculated correctly thats about 1/8 octive at the narrowest. Pretty narrow but a far cry from the (admittedly overkill of ) 1/60 of some of the other units Last edited by random username; 03-10-09 at 06:51 PM.. | ||||
| | #4 | |||||
It has 1/60-octave resolution on the frequency scale (e.g. 60 stops between say, 50-100 Hz), and also on the bandwidth scale (i.e. between the narrowest filter and a 1-octave filter, and between a 1-octave and 2-octave filter). By comparison, the FBQ also has 1/60-octave resolution on the frequency scale, but not on the bandwidth scale, where its resolution significantly decreases at wider filter settings. This might be something to take into account for subwoofer equalizing. Typical subwoofer equalizing requires filter bandwidths between ~1/8-1/3 octave. In that range, the BFD has 14 available settings, while the FBQ only has five. As you can see, the BFD is capable of more precise and accurate filter settings. Overkill? Perhaps. But surgical precision is what a parametric EQ is all about, is it not? I don't know if the DCX's EQ settings are the same as the FBQ, but as least now you have some guidelines for determining how capable it is. Regards, Wayne | |||||
| | #5 | ||||
| Re: DCX2496 does this work like the FBQ2496 to eq? thanks for the reply. I ended up stumbling upon a BFD for $45 in good shape, made some adaptors to convert to the TRS 1/4" last night and am up and running now. Pretty easy to use, really...I don't think i'll ever go to the trouble of hooking a MIDI cable up to link with REW..I like the hands on approach. I really wish there was a unit just like the BFD, low cost but three channels (two input and three out). I wish to high pass the mains without affecting the sub. Also wish to smooth out the 80-150 Hz region and will need to boost part of that for the mains, as my mains roll off in that area. I may just end up with two BFDs, stacked...or a BFD for sub and FBQ for mains. | ||||
| | #6 | ||||||
..it's called the DCX!Pre: TAS Processor Eq: DCX 2496 Power: Behringer A500, Ebony 290w x4 Source: Sony DVD Front: Tag 2.6 Center: n/a Rear: Yamaha NS-225 Subs: Whise 624 | ||||||
| | #7 | |||||
![]() Regards, Wayne | |||||
| | #8 | ||||
| Re: DCX2496 does this work like the FBQ2496 to eq? true. Really the entire brand name we are talking about here sells a low cost alternative to other "premium" brands. I don't mind paying as long as I know I"m getting what I want. after playing with the BFD today, I gotta say I wouldn't want to give up much on how narrow the bandwidth will go. Just getting started, I'm using a 3/60 bandwidth eq...and expect to probably need even narrower eventually. Now, one could argue that if there's a peak or valley that narrow that you can't hear it, which in some cases may be true. All I know is on REW, what i'm correcting looks like something that needs to be fixed unless I use the 1/3 octave smoothing. Also, I can hear the peaks/valleys during the sweep. Last edited by random username; 03-14-09 at 11:55 AM.. | ||||
| | #9 | ||||||
The object of equalizing is not to create a perfect graph. Ultimately it's to improve sound quality, and you don't need razor-sharp filters to accomplish that, as typically the most audible problems are broad and/or deep deviations in response. I suggest taking the time to peruse my minimal EQ article. You can find a link in my signature. Regards, Wayne | ||||||
| | #10 | |||||
The FBQ's minimum bandwidth is 1/60 just like the BFD. Last edited by random username; 03-19-09 at 07:48 PM.. | |||||
| | #11 | ||||
| Re: DCX2496 does this work like the FBQ2496 to eq? Well, I can see that if it's a "nasty peak," meaning (I assume) that it's really severe, an ultra-narrow filter like that would be needed simply to minimize the filter "bleeding" into areas on either side of it where there is no problem - if that makes sense. This is because of a filter's natural tendency to spread wider and wider as gain changes increase. So - I guess you'll be adding a BFD dedicated to the Subs... ![]() Regards, Wayne | ||||
| | #12 | ||||
| Re: DCX2496 does this work like the FBQ2496 to eq? Speaking of BFD's and multiple subs, how exactly do you hook up multiple subwoofers? Would I need to use a splitter at the sub out of my receiver/preamp, or is there a different way to hook things up? I have the 1124p. | ||||
| | #13 | ||||
| Re: DCX2496 does this work like the FBQ2496 to eq? You can split the sub signal leaving the receiver and feed both channels of the BFD, then feed the two subs with the two channels of the BFD, then each sub can have it's own set of filters. | ||||
| | #14 | ||||
| Re: DCX2496 does this work like the FBQ2496 to eq? Or, if your subs are co-located, you could single-cable it all the way, and split right at the sub inputs. Regards, Wayne | ||||
| | #15 | ||||
| Re: DCX2496 does this work like the FBQ2496 to eq? Thanks guys. I tried the splitter at the receiver's "sub out" and it sounded pretty bad. Measurements confirmed that from 30 - 15hz, the FR dropped 15dB pretty quickly. I am powering dual sealed TC2000 15's with a Behringer EP2500. I assume it just doesn't have enough power to bring up the low end on dual TC drivers? Once I switch back to bridged mode and run one sub, it's beautiful. I know they are power hungry suckers, so... I will using one cable and splitter at the amps connection instead. Thank you both. | ||||
| | #16 | ||||
| Re: DCX2496 does this work like the FBQ2496 to eq? Spitting the signal will effect only its level. It will have no effect on frequency response. You probably didn't have something downstream set up right - like mismatched filters in the two BFD channels, some setting on the amp, etc. Also, if you're using a single EP2500 for the two subs, you don't need a splitter at all. You can set the amp to "parallel" mode and drive both outputs with either input. Regards, Wayne | ||||
| | #17 | |||||
So how would I not need a splitter from the amp to the receiver's subwoofer out? I still have two cables going from the amp to the receiver's one subwoofer output. Can I connect one subwoofer to the receiver's subwoofer out and another to the receiver's preout? I will give it a go again. Thank you. | |||||
| | #18 | |||||
| | #19 | |||||
| | #20 | ||||
| Re: DCX2496 does this work like the FBQ2496 to eq? Nope. Bridging basically turns a stereo amp into a mono amp. Regards, Wayne | ||||
| | #21 | ||||
| Re: DCX2496 does this work like the FBQ2496 to eq? As an update, here is what I ended up with for an in-room FR after switching to parallel mode (which is what my issues was - thanks Wayne). ![]() I only had to add a few filters. The subs are co-located and sound great, but I definitely need more power (a behringer ep2500 for each). In which case, I assume I'd have no choice but to split the signal right at the receiver's subwoofer output? Or is there some way to pigtail the EP2500's? Last edited by Nuance; 03-27-09 at 02:32 PM.. | ||||
| | #22 | |||||
| | #23 | |||||
You've been a HUGE help, Wayne. I am just reading through your tips on house curves now...really good stuff. You've given something to "play with" (as my wife calls it) this weekend. Thanks again! Last edited by Nuance; 03-27-09 at 05:15 PM.. | |||||
| | #24 | ||||
| Re: DCX2496 does this work like the FBQ2496 to eq? Thanks for the kind words, Brandon. You'll want the EP-2500's manual, for the details on parallel mode, not the BFD's.Regards, Wayne | ||||
| | #25 | ||||
| Re: DCX2496 does this work like the FBQ2496 to eq? Oops - yeah, that's what I meant (the ep2500 manual). Thanks again! | ||||
