| BFD | Electronic Equalization Devices BFD 1124P High Pass FilterDiscuss BFD 1124P High Pass Filter in the Equalization | Calibration forum; BFD 1124P High Pass Filter I have been using WinISD to model various designs for a HT sub I am planning to build. When modeling ... |
Views: 531 - Replies: 8
| BFD 1124P High Pass Filter I have been using WinISD to model various designs for a HT sub I am planning to build. When modeling I apply a high pass filter to prevent exceeding max cone excursion at low hz levels. For example, is it possible to apply a 3rd order high pass filter at 14.25hz using the BFD 1124P? If so, how easy is it to do for someone who has never used a DSP before? | ||||
| | #2 | |||||
| Re: BFD 1124P High Pass Filter Quote:
brucek | |||||
| | #3 | ||||
| Re: BFD 1124P High Pass Filter Is a high pass filter something that is normally integrated into the amp, or are there other DSPs out there that can do high pass filters? | ||||
| | #4 | ||||
| Re: BFD 1124P High Pass Filter While many (if not most) pro audio equalizers have on-board low- and high-pass filters, the BFD does not. As you may know, a high- (or low-) pass filters continually roll out response at a set rate per octave. Since the BFD has no HP or LP filters the best it can offer is one if its standard EQ filters. These will eventually flatten, not continually drop. Many amps have low pass filters, but I’ve never seen one as low as 14 Hz. Typically you will need an outboard device to accomplish this. Regards, Wayne | ||||
| | #5 | |||||
| | #6 | |||||
| | #7 | ||||
| Re: BFD 1124P High Pass Filter You might want to avoid the B1. IIR brucek did a review on one a while back and found that it has inadequate capacitors that will eventually self destruct. Regards, Wayne | ||||
| | #8 | ||||
| Re: BFD 1124P High Pass Filter I have not heard of any issues with the Reckhorn B1. It has been stated that the ED eq.2 does not work well with pro amps due to it's inability to boost the input voltage. | ||||
| | #9 | ||||
| Re: BFD 1124P High Pass Filter My goof, it was the FI electronic crossover, not the B1. Still, brucek's findings with the F1 don't exactly inspire confidence... http://www.hometheatershack.com/foru...fications.html Regards, Wayne | ||||
