DCX2496 Unbalanced Output
Discuss DCX2496 Unbalanced Output in the Equalization | Calibration forum; DCX2496 Unbalanced Output I have just ordered a DCX2496 and am now working on the cabling required. All my sources and amplifiers have ...
Views: 582 - Replies: 1
Old 03-14-09, 01:32 PM   #1
Alias: Paul
Loc: Waynesville, NC
User: #13486
Since: Nov 2007
  pcasper is offline
I have just ordered a DCX2496 and am now working on the cabling required. All my sources and amplifiers have balanced interfaces, except for my subwoofers. One of the output channels from the DCX will drive my sub amps, which have unbalanced inputs. The DCX has balanced XLR outputs only. From the DCX manual I gather that it is acceptable to short XLR balanced output pins 1 and 3 together, with pin 2 being the hot pin for unbalanced drive. I want to make sure this is doable before I blow the negative output pin driver. Could someone please confirm that this is safe? Thank you!
Paul
Old 03-14-09, 04:02 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: DCX2496 Unbalanced Output
Just like all Behringer products, the input/outputs can be used in the unbalanced mode by bridging pins 1 and 3 of XLR connections or using a TS connector in the 1/4" jacks.
dcx2496, output, unbalanced
