| BFD | Electronic Equalization Devices Level meters when using only Left channelDiscuss Level meters when using only Left channel in the Equalization | Calibration forum; Level meters when using only Left channel Hello,
I looked in the manual and in the FAQ.. but didn't see a good answer to my really simple ... |
Views: 400 - Replies: 4
| Level meters when using only Left channel Hello, I looked in the manual and in the FAQ.. but didn't see a good answer to my really simple question. I have a DSP1100 and I am using only a couple PA filters. I purchased it used - so as a sanity check I wanted to make sure that I understood the level meters properly. When using only the Left channel (ie, LFE line level input) - both of the level meters light up. It behaves almost as if the left meter is pre-filter level and the right meter is post-filter level. Is that correct? Only filters are enabled for the Left channel - although they are defined for both L+R. I noticed that when the input is plugged into the Right input - only the right line level appears to be active. I figured that this is some behavior that only occurs when using only the L channel - so that it can make use of both level LED bars. Could someone confirm that I'm on the right track? If I missed this in some really obvious post - I apologize. Thanks in advance. | ||||
| | #2 | |||||
| Re: Level meters when using only Left channel Welcome to the Forum! Quote:
Regardless, it won't affect the way it works. Regards, Wayne | |||||
| | #3 | |||||
| Re: Level meters when using only Left channel Quote:
| | #4 | ||||
| Re: Level meters when using only Left channel Most Pro-equiment uses the left channel as mono input. If i remember correctly, i had the same 'issue' in my BFD back when I owned one. | ||||
| | #5 | |||||
I had some more time to test it and I found that the L meter would show the level after the filters have been applied and the right meter would show the actual line level. I tested with filters that increased and decreased the gain - and every time the left level display changed in intensity correctly - relative to the right meter. If the EQ was out - then both L and R would show the same level (the L channel). Thanks for everyones help. I look forward to spending some more time soaking up the knowlege here! | |||||
