BFD Systemic Problem with Hum
Discuss BFD Systemic Problem with Hum in the Equalization | Calibration forum; BFD Systemic Problem with Hum I see many recommendations on the forum to use a BFD to smooth out the bass response and I can ...
Views: 252 - Replies: 4
Old 06-30-09, 01:14 AM   #1
Silver Supporter
Alias: Lester
waldo563's Avatar
Loc: Longmont, CO
User: #36847
Since: Apr 2009
  waldo563 is offline
I see many recommendations on the forum to use a BFD to smooth out the bass response and I can see where it is very helpful from the before/after graphs. However, I also see a lot of postings describing a problem with BFD humming which seems to be widespread. I would like to get a BFD to help with the bass response but in light of all of the ground loop problems, it seems like it may be better to live with uneven bass response than fighting a systemic ground loop problem. It appears that the ground loop problem is solvable but I has seen so many posts with differing solutions that I'm a little confused. I just don't want to get one and then end up having to live with an annoying hum. Any recommendations or clarification would be appreciated.
The early bird may get the worm, but the second mouse gets the cheese.
Old 06-30-09, 06:37 AM   #2
Alias: hjones4841
hjones4841's Avatar
Loc: Central AL
User: #32516
Since: Jan 2009
  hjones4841 is offline
Re: BFD Systemic Problem with Hum
There is a whole thread on solutions to BFD hum. The issue is ground loops which are not necessarily unique to the BFD - I had the same problem with a well regarded Parasound power amp years ago.
Some solutions are not difficult to try. Decision is obviously up to you, but the improvement that a BFD can make is well worth the low cost of admission and the effort to set it up properly.
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
Old 06-30-09, 07:06 AM   #3
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
I certainly wouldn't describe the hum problem as "widespread." Consider that the people who haven't had a problem with it are at something of an disadvantage here as far as threads and discussions go, because they (obviously) don't have a reason to bring the issue up! So the exposure you're seeing here is heavily one-sided. At the end of the day, the great majority of users who do have the hum problem are able to find a remedy to eliminate it. So there's no reason to let that keep you living with poor bass response.
Old 06-30-09, 06:01 PM   #4
Silver Supporter
Alias: Lester
waldo563's Avatar
Loc: Longmont, CO
User: #36847
Since: Apr 2009
  waldo563 is offline
Wayne, hjones4841
Thanks for the clarification. You bring up good points about the posts being biased towards problems for obvious reasons and the fact that ground loop hum is not restricted to the BFD. As long as the hum issue is resolvable without an extraordinary amount of effort or cost, I will have to consider purchasing one in the near future once I have completed or mostly completed my room treatments.
On a side note, I came across a thread which was essentially a survey asking forum members if they would vote for new and improved option A/option B Behringer Feedback Destroyers with the option B feature set being more extensive. The results of the survey would be brought to Behringer as a petition for product improvement. Did anything ever come of this? I believe it was from the 2006 timeframe.
Thanks
Old 06-30-09, 08:46 PM   #5
Alias: Wayne
Loc: Katy, Texas
User: #8
Nah. It was our effort to convince Behringer to manufacture an EQ that was more friendly to residential applications; the "A," "B" thing was our wish list for features and functions. Behringer seemed interested, but nothing ultimately came of it. It's kinda moot at this point, as there are now several options available for dedicated subwoofer Equalizers.
bass response, bfd, hum
