| BFD | Electronic Equalization Devices SMS-1 Update to 2.1.3Discuss SMS-1 Update to 2.1.3 in the Equalization | Calibration forum; SMS-1 Update to 2.1.3 I recently purchased a SMS-1 that never had the firmware updated to 2.1.3. I tried to do it last night ... |
Views: 307 - Replies: 3
| SMS-1 Update to 2.1.3 I recently purchased a SMS-1 that never had the firmware updated to 2.1.3. I tried to do it last night and it appeared everything was successful. SMS-1 screen was flashing and messaged said update was successful. The problem is that when I look at the version on the main menu, it still says 2.1 Is that was happens with the update? Or should the menu say 2.1.3 Thanks Darryl | ||||
| | #2 | ||||
| Re: SMS-1 Update to 2.1.3 I was able to get the SMS-1 updated. Although it went through the entire procedure and said update was successful, I still had the old version. I was updating with a USB to Serial cable. When I changed to a PC that had a real serial cable, I was able to successfully update. Darryl | ||||
| | #3 | ||||
| Re: SMS-1 Update to 2.1.3 Had a similar experience. Unit came with the old (2.1) FW, so I ordered a USB-RS232 hybrid cable from monoprice, and it looked with everything was going to be simple: the update indicated that it went through OK, but it didn't 'take' on the unit; i.e., it still showed the old FW. The problem was that I needed to load the 'driver' for the USB cable, and unfortunately the disk for this didn't come with the cable. Fortunately a friend, who is a computer guru, came by and was able to find the driver on the internet, load it, and then everything took less than a minute. Happily now at 2.1.3, but I would NEVER have figured this out on my own. | ||||
| | #4 | |||||
| Re: SMS-1 Update to 2.1.3 Quote:
Finally a friend took all of 5 minutes to get it done. | |||||
