Connecting one sub to two systems
Discuss Connecting one sub to two systems in the Equalization | Calibration forum; Connecting one sub to two systems I'm trying to connect BFD (input) right and left channels to two separate preamps and outputs to right and left ...
Views: 229 - Replies: 3
Old 08-12-09, 06:56 AM   #1
New Member
Alias: josko
User: #37379
Since: May 2009
  josko is offline
I'm trying to connect BFD (input) right and left channels to two separate preamps and outputs to right and left channels on a sub. It would seem that the sub would play whatever signal comes down from either system, and use a different EQ setup for each. Can anybody see a reason this would not be a good idea? Is there a potential problem I'm overlooking?
Old 08-12-09, 08:30 AM   #2
Alias: brucek
User: #6
  brucek is offline
Re: Connecting one sub to two systems
Are you feeding one system into the BFD left channel only and the other system into the BFD right channel only?
Old 08-12-09, 11:18 AM   #3
New Member
Alias: josko
User: #37379
Since: May 2009
  josko is offline
That's correct. I'm feeding one system's mono subwoofer output to the BFD left channel, and the other system's (mono subwoofer output) to the BFD right channel.
Old 08-12-09, 12:43 PM   #4
Alias: brucek
User: #6
  brucek is offline
I see no problem then, as long as the sub you are feeding accepts a left only or right only signal to achieve the full power output....
connecting, systems
