| BFD | Electronic Equalization Devices Digital Room Correction for the rest of us?Discuss Digital Room Correction for the rest of us? in the Equalization | Calibration forum; Digital Room Correction for the rest of us? In my exploration to find a suitable, inexpensive digital room correction system I came across KRK Ergo. It is located ... |
Views: 568 - Replies: 20
| | #1 | |||||
| Digital Room Correction for the rest of us? In my exploration to find a suitable, inexpensive digital room correction system I came across KRK Ergo. It is located here. It peaked my interest because it has Lyngdorf's Room Perfect Technology in it. Here is an excerpt from the website: Quote:
The best part of it all, and the part that has me all hot and bothered is the price. It can be found online for $499-$699 if you don't mind hunting a bit. My2Cents | |||||
| | #3 | ||||||
| Re: Digital Room Correction for the rest of us? Quote:
Kal Rubinson __________________________________ "Music in the Round" Contributing Editor, Stereophile | ||||||
| | #4 | ||||
| Re: Digital Room Correction for the rest of us? And that's the reason the Ergo has my interest. Well that and the fact that other DR devices run many thousands of $$'s. I run a 2-Channel System with integrated amplifier sans subwoofer. BFD, and other devices are unnecessary. But because my system is in a very confined and akwardly shaped space, I have began to look at digital room correction devices to help bring my music into greater focus. I also plan to use simple physical room treatments to help mitigate negative room interactions on the sound. My2Cents | ||||
| | #5 | ||||
| Re: Digital Room Correction for the rest of us? A McIntosh product with DRC. Is this a marriage of convenience, or natural evolution of Mac products?? ![]() Great. I'm trying to read up on the specifications of the unit to get more info about how it works and what hardware it's using to do what it does, ie. internal components. I'd like to know what my audio signal is going through before it gets to my ears. We know the Ergo will have a negative sonic signature**. The question then becomes, will that sonic signature outweight the benefits of DRC the unit is providing? ** Working from the idea that ANYTHING you put into the audio signal path will have a negative effect on it. My2Cents | ||||
| | #6 | ||||||
| | #7 | ||||
| Re: Digital Room Correction for the rest of us? Analog Old-Think. I can dig that. With either process, D/A or A/D, the quality of the product is important and has a role in shaping the overall sound quality of the system. In such a system, well thought out and designed, knowing what each product is doing and at what level is important when making decisions involving greenbacks. My2Cents | ||||
| | #8 | |||||
| | #9 | ||||
| Re: Digital Room Correction for the rest of us? I'd like to know what hardware their using for A/D, and D/A conversion. It lists the processing being handled by the Analog Devices 400 MHz BlackFin processor. Nothing specified about the other audio processing. The volume control is analog, wonder what volume pot there using. My system consists of Cambridge Audio (CA) Azur 840A Integrated Amp, CA DAC Magic, Oppo DV-980H as a transport, HTPC (via SPDIF output) as my primary digital audio source, Comcast Cable box. Where does the Ergo get placed into my system? In between the source and the integrated amplifier? My2Cents | ||||
| | #10 | ||||
| Re: Digital Room Correction for the rest of us? I just saw a video over at youtube of a KBK rep describing the Ergo in more detail. It uses AKM 4396 D/A Converters which has 120db S/N. It also uses a Digitally Controlled Analog Volume Control. My2Cents | ||||
| | #12 | |||||
Regards, Wayne | |||||
| | #13 | ||||
| Re: Digital Room Correction for the rest of us? So I would go: DAC Magic SPDIF Out ----> Ergo SPDIF In ----> Ergo Out to Speakers??? My2Cents | ||||
| | #14 | ||||
| Re: Digital Room Correction for the rest of us? What’s the (recommended retail price) on this product and what is the possible lowest selling price at most PA outlet stores. Edit:Forget it I need to buy glasses more than a new sound system product. I see it at the top of the OP page. That’s too far too expensive.70mm was regarded as the Rolls Royce of picture and sound in its day. | ||||
| | #15 | |||||
Forgot to mention, if the integrated amp has pre-out and main-in connections, you can insert it there - again, analog connections. Cheers, Wayne | |||||
| | #16 | ||||
| Re: Digital Room Correction for the rest of us? Ok I've got it now. I would go SPDIF out of the DAC -----> SPDIF In on Ergo ------> Line Level out to Integrated. Illustrated below. The "Speakers" A ( or B) Output on the Ergo are Line Level outputs. ![]() I would need a 1/4" Phono to RCA adapter to insert into an input on my integrated. ![]() And that's it. My2Cents | ||||
| | #17 | ||||
| Re: Digital Room Correction for the rest of us? Or maybe some cables with the correct ends... ![]() Regards, Wayne | ||||
| | #19 | ||||
| Re: Digital Room Correction for the rest of us? After a day's worth of research I have dug up a good deal more info on the Ergo. It has been well discussed on international forums like stereo.net.au, and over at Britans Harbeth forum, and one other I can't remember the name of. It is a real alternative to expensive product like the Lyngdof/TACT product and Audyssey. I may pull the trigger. My2Cents | ||||
| | #21 | ||||
| Re: Digital Room Correction for the rest of us? I have yet to actually purchase the unit, but I have read over at another forum that the quality of the DAC is very high. My2Cents | ||||
| Bookmarks |
| Tags |
| correction, krk ergo, room |
| Thread Tools | |
