| BFD | Electronic Equalization Devices Using DCX2496 as EQ and crossover with REWDiscuss Using DCX2496 as EQ and crossover with REW in the Equalization | Calibration forum; Using DCX2496 as EQ and crossover with REW Hi,
As I do not own the device above I have the following question:
It is possible to make 'EQ-ing' ... |
Views: 350 - Replies: 13
| Using DCX2496 as EQ and crossover with REW Hi, As I do not own the device above I have the following question: It is possible to make 'EQ-ing' and a lowpass filter using the REW software with this device? BG | ||||
| | #2 | |||||
| Re: Using DCX2496 as EQ and crossover with REW Quote:
brucek | |||||
| | #3 | ||||
| Re: Using DCX2496 as EQ and crossover with REW You can produce something that "looks" correct on an REW graph using several filters, but it's not going to have the infinite drop in response that a true LP filter will have (i.e., -24 dB at one octave, -48 dB at 2 octaves, etc.). Plus, each EQ filter used introduces some phase, while that's only a single "occurrence" with a real LP (for lack of a better word). All in all, it's not the best way to do things. Doesn't your receiver have a built-in crossover? Regards, Wayne | ||||
| | #4 | |||||
brucek | |||||
| | #5 | ||||
| Re: Using DCX2496 as EQ and crossover with REW Ah - looks like I confused it with that other 2496 model - again... Regards, Wayne | ||||
| | #6 | |||||
| Quote:
Posted via Mobile Device | |||||
| | #7 | ||||
| Re: Using DCX2496 as EQ and crossover with REW It's not entirely clear from your opening post exactly what you're looking for, but the DCX has both EQ and crossover filters. Regards, Wayne | ||||
| | #8 | |||||
I want to have a crossover between my sub and the satelites and be able to add the EQ'ing to the sub. Hope the above is more clear, otherwise let me know. Regards, Tue | |||||
| | #9 | |||||
brucek | |||||
| | #11 | ||||
| Re: Using DCX2496 as EQ and crossover with REW So what are some other brands that have the ability to control all your speakers/subs. Is there any better units out there then what berriger offers? Or is the DCX-2496 the main player. I like the idea of maximum control with cross overs and the ability to EQ the mains and subs seperate and bye pass audessey all together. It seems alot of people that run the JTR perfer not to use audessey anyway so it would be nice to see if I could make my setup sound better through rew and my own settings then what audessey comes up with. I figure I can always go back if it doesen't work out and just use it for my subs. Thanks Scott | ||||
| | #12 | |||||
The best route in my opinion is to EQ the sub(s) and leave the mains alone... brucek | |||||
| | #13 | ||||||
Regards, Wayne | ||||||
| | #14 | ||||
| Re: Using DCX2496 as EQ and crossover with REW I have seperate amps for my front stage JTR triple 12s running 2 crest 8200 pro amps and rotel rb-1090 pushing 700 watts to the triple 8s for surrounds. So everthing is powered seperate. Scott | ||||
