| BFD | Electronic Equalization Devices SSF project prototype previewDiscuss SSF project prototype preview in the Equalization | Calibration forum; SSF project prototype preview I'd like to share some info about an exciting SSF project I have been working on for many months. I ... |
Views: 392 - Replies: 27
| SSF project prototype preview I'd like to share some info about an exciting SSF project I have been working on for many months. I now have some prototype hardware. In summary it will be an adjustable SSF filter with 0.1Hz resolution, different gain settings, and preset filter types. ![]() As seen in the photo above, it has a 3 digit LCD, AC power supply, RCA input, and a 1/4" phono balanced output. A microcontroller controls the LCD, frequency, and filter type on the analog board. I haven't written the microcontroller code yet, but I have assembled and am testing the analog board shown below. ![]() There are 8 selectable gain settings from 0dB to 13dB (plus an additional 6dB for a balanced output). The following graph shows the response of the input stage before the HPF. ![]() The filter frequency is controlled by a clock signal generated by the microcontroller. In this testing I used an external signal. The following graph shows the consistency of the response as the frequency is varied. ![]() The last graph shows the frequency response in the following modes: 2nd order butterworth, and 2nd order peaking filters with peaking of 3.0dB, 2.25dB, 1.5dB, and 0.7dB (Q=1.3066, 1.172, 1.044, 0.904). There will also be a 4th order butterworth mode. I found that the SSF frequency was very accurate. ![]() Please hold off on the extensive questioning - let me save my precious free time for working on the project. Don't hold off on the encouragement though ![]() Last edited by SturmMD; 10-06-09 at 12:11 AM.. | ||||
| | #3 | ||||
| Re: SSF project prototype preview Looking Good! | ||||
| | #4 | ||||
| Re: SSF project prototype preview Those boards look fantastic!! ![]() | ||||
| | #6 | ||||
| Re: SSF project prototype preview | ||||
| | #7 | ||||
| Re: SSF project prototype preview Your on to something here SturmMD, Looking forward to the finished product ![]() Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #8 | ||||
| Re: SSF project prototype preview 1+ Looks primising. I'm sure you already know this but you have a couple competitors priced just under a $100. I really like the accuracy of your filters and the adjustable output gain (especially WRT using this with prosound amps). Keep up the good work! | ||||
| | #9 | |||||
| Re: SSF project prototype preview Quote:
| | #10 | ||||
| Re: SSF project prototype preview Hmm. I have tried contacting Bob @ CSS a couple times with questions about the Reckhorn B2 but I keep getting pointed to this forum (with most of the questions going unanswered). He admitted that the 10Hz SSF is really about 12Hz. If you're saying the top dog suggested you do your own testing on your device to be sure it's doing what you want it to (and he's suggesting it may not), that brings to mind serious issues with the reliablity of the product. If SturmMD's new mule does what the B2 does but more reliably then sign me up (especially if the cost is similar). | ||||
| | #11 | ||||
| Re: SSF project prototype preview Hi Sturm, Can you give more details about the project? Is this intended to be produced so that anybody can buy? Do you expect a release date soon? ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #12 | |||||
Sturm's device, at least to me, would be worth more than the off-the-shelf devices currently available, even if you have to build it yourself from a parts list. (I better start saving!) | |||||
| | #13 | |||||
brucek | |||||
| | #14 | ||||
| Re: SSF project prototype preview Old computer, no rew...my opinion is unless sturm's design is either faulty or quite costly, manufacturers should be making a better mousetrap rather than expecting the consumer to (unnecessarily) have additional (costly) equipment to use their device accurately and follow up my making marks on the face. Could you imagine after purchasing your automobile having to buy a radar gun and test your vehicle throughout the speedometer's range, and then write the actual speeds on the dash with a sharpie??? ![]() | ||||
| | #15 | ||||
| Re: SSF project prototype preview Not only that, but testing the accuracy of your SSF in room is pretty difficult given all the interactions with room boundries. One would need to take your box outside and lift it up with a fork lift a la Kevin Haskins. Hard to do with an IB sub. | ||||
| | #16 | ||||||
brucek | ||||||
| | #18 | |||||
... and would be pretty easy to do. The only risk is it may be like luck of the draw on accuracy. The 10Hz SSF may be 12Hz but it could be 14Hz. Same with the boost at 20Hz. I suppose if a device tests inaccurate enough one could return it... but then shipping costs get involved. Do you take a chance on a second device that may be better or possibly even worse? I suppose it depends on the whether the manufacturer pays for shipping. | |||||
| | #19 | ||||
| Re: SSF project prototype preview SturmMD. Sorry for going OT. Your device looks cool and I can't wait to see how it turns out. If your device is more accurate than your comps then you will have a real place in the market. Good luck. | ||||
| | #21 | ||||
| Re: SSF project prototype preview I've been trying to find time to start working on the microcontroller code. I have a deadline at work next week that I have been working on recently. After that I hope to get to it. | ||||
| | #23 | ||||
| Re: SSF project prototype preview Have you had any time to work on this? It has every feature I want... a highly adjustable and accurate SSF, one band of highly adjustable parametric EQ, an RCA input and a fully balanced XLR output with adjustible gain and the requisite +6dB gain. That would be perfect for an infinite baffle sub using a pro amp. One specific question... do you know if a time delay is induced when the SSF and/or parametric EQ are used? I ask because my receiver has a very sophisticated auto EQ that measure and accounts for time delay to the msec. The problem is it autocorrects to a flat response. I would like to have the SSF implemented before the auto EQ is run but I would implement the boost at 20Hz afterwards to create a house curve. The drawback is if there is too much of a delay it could make things worse. Please keep this in mind as many receivers and pre/pros have very sophisticated auto EQ programs and a lot of people use them. | ||||
| | #24 | ||||||
One point I'd like to clarify is that the "parametric EQ" (the gain peaking) is linked to the highpass frequency since I am just changing the Q of the filter. There is not a peaking filter separate from the subsonic filter so you cannot set the subsonic filter and then dial in gain at as specific frequency. You can use this program written by Collo to quickly graph the peaking filter choices of this circuit. Select "peaking" to see how the circuits response reacts to the different gain presets. Right now the circuit has 0.7, 1.5, 2.25, and 3dB peaking settings. Similarly, you can use WinISD to plot the group delay of these filters. Use type: highpass, SOS user-specified, 2nd order, and Q values of 0.904, 1.037, 1.172, or 1.307. The following pictures are an example of this One important thing to consider is to also include all the highpass poles of the signal chain in the simulation. I have measured mine as (1st order poles) Receiver 2.5Hz, BFD 3.7Hz, EP2500 4.1Hz, and SSF 1.95Hz. My signal chain alone creates the following group delay (in milliseconds); which is unavoidable besides reducing the amount of equipment in the signal chain. ![]() The next figures uses my PR sub design as I compare the different filter options: (blue) 4th order butterworth (white) 2nd order butterworth (yellow) 2nd order, 0.7dB (Q=0.904) (orange) 2nd order, 1.5dB (Q=1.037) (red) 2nd order peaking, 2.25dB (Q=1.172) (green) 2nd order peaking, 3.0dB (Q=1.307) I adjusted their frequencies so that they had equal height peaks (below and above tuning frequency) in the cone excursion graph. ![]() When comparing two filter choices, any advantages (higher excursion at a lower frequency) in this graph translate to small, but meaningful (~1dB) SPL output advantages. For the peaking filters I also reduced their gain by the equivalent amount so that the comparisons would be fair. The final filter transfer functions (with signal chain) are then shown below. ![]() and the additional group delay (ms) caused just by the filter type choice. ![]() So you can see that you just have to compare the simulations and make tradeoffs between group delay and the low frequency extension. Last edited by SturmMD; 11-17-09 at 01:56 AM.. | ||||||
| Bookmarks |
| Tags |
| adjustable, prototype, ssf |
| Thread Tools | |
