BFD Bypass
Discuss BFD Bypass in the Equalization | Calibration forum; BFD Bypass Is there a way to bypass all the filtering present in the Behringer whilst leaving to connected? I have purchased ...
Views: 111 - Replies: 2
Old 10-29-09, 02:18 AM   #1
Alias: VicM
Loc: South Africa
User: #16214
Since: Jan 2008
  vmaharaj is offline
BFD Bypass
Is there a way to bypass all the filtering present in the Behringer whilst leaving to connected? I have purchased a new AVR and want to run Audyssey first before equalising with the BFD. It is just too much work disconnecting everything and then reconnecting again. Alternatively, how can I reset all the filters that are present in the BFD from previous equalisations?
Old 10-29-09, 08:14 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: BFD Bypass
The in/out switch bypasses the filters on the BFD. Refer to the manual for its operation.
Old 10-29-09, 10:26 AM   #3
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: BFD Bypass
There is no "Reset" function. You either have to turn off each filter manually by changing its gain setting from (+) or (-) to zero, switch the filter from "PA" to "OF" (off), or re-adjust the filters to any new settings you might choose. Alternately, you could "abandon" one memory setting and enter new filters in a different one.
Or as brucek mentioned, you can bypass everything with the front panel button.
bypass
